Salas DCG3 preamp (line & headphone)
Old 16th April 2019, 02:35 PM   #3771
Brakspear75 is offline Brakspear75  United Kingdom
Connect the primary to mains and use a voltmeter to check you've got 18V ac on each of the secondaries. Power off, hook two secondary wires together to give a centre tap, I'd guess one red, one black. Power up & verify 18V from centre tap to either end. Now check voltage from one end to the other - if the secondaries are in phase you'll have 36V, if the voltage is nowhere near that then swap the wires on one secondary only so the opposite colour is tied to form the centre tap. Recheck voltages to confirm 18V from centre to either end & 36V end to end. Done.
Or wait for a reply from someone who's used these transformers already ��
Old 16th April 2019, 02:43 PM   #3772
killie99 is offline killie99
Thanks Brakspear, yes that seems the sensible thing to do rather than relying on the bits of sticky tape. Wonder why Toriody don't use different coloured wires like everyone else?
Old 18th April 2019, 10:18 AM   #3773
transcendent is offline transcendent
While this is not a digital line level part of the forum, I wanted to ask what DAC's everyone has been using (if using) in combination with DCG3 preamp.
I've read few positive posts about Soekris DAC. Any opinions on it?
Old 18th April 2019, 10:33 AM   #3774
So the DCSTB I've bought has the wrong value resistors in locations R1 and R2, 1 ohm resistors are fitted rather than 33.2 ohm Dales (also had some of the transistors in the wrong places but thankfully has never been powered up).
I have some CFR25 Carbon Film 33Ω ±5% 0.33W -1200 → 0ppm/°C, are these suitable to be used instead of the Dales for R1 and R2?
Old 18th April 2019, 11:11 AM   #3775
dewdrop is offline dewdrop  Singapore
I have a Soekris 1121 playing through the DCG3. All the power supplies are using UBiB v1.3, 7 in total. You won’t be disappointed.
Ed
Old 18th April 2019, 11:46 AM   #3776
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Uninspiring ppm spec but since that is a constant current position that will bring them to more or less constant working temp you may use them.
Old 18th April 2019, 01:47 PM   #3777
Thanks dewdrop for the feedback ! What did you use for USB to I2S module?
Old 18th April 2019, 10:04 PM   #3778
steefdebruijn is offline steefdebruijn  Netherlands
With all the trafos I used from them the output wires were always coming out of the trafo in the same “winding order”, so with red1, red2, blue1, blue2 coming out the inner wires red2, blue1 should be the “center tap”. But measure as stated above to be absolutely sure.
Old 20th April 2019, 01:11 AM   #3779
I use a Pi2B for direct I2S connection to the DAM 1121.
Ed
Old 20th April 2019, 08:31 AM   #3780
Yes, that's how they are wired. thanks.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
Copyright ©1999-2019 diyAudio
