Salas DCG3 preamp (line & headphone)
Old 7th February 2019, 03:46 PM   #3561
domenico80 is offline domenico80  Italy
Originally Posted by Salas View Post
3X is translated to near 10dB. Proved practical enough with most amps and headphones. 17dB to 20dB is usually too much with modern digital sources.
thank you
I agree for the 10 db, enough and advance with the digital
with a line like this I have no problem connecting the power final to a volume potentiometer
Old 7th February 2019, 06:50 PM   #3562
IDM is offline IDM  United Kingdom
I think I have found the fault. I measured voltage across the input to the bad channel and rather shockingly there is 8.6V. So I can only assume its the UPA68H that has failed or was bad when I put it in. Unfortunately I have no spares.
Looking on Ebay the chines ones are very cheap whereas the UK ones are pretty expensive. Can someone recommend a reliable source?
Ian
Old 7th February 2019, 08:43 PM   #3563
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Ask Tea to send you a surely adequate couple of spares. Its a lottery with so many fake semis or factory rejects out there.
Old 7th February 2019, 08:49 PM   #3564
even retailers in the Far East falsify the transistor codes
When test circuits , fireworks happen
Old 7th February 2019, 09:06 PM   #3565
Salas's Avatar
P.S. Meanwhile better remove the suspect package to verify damage on the transistor tester. Three legs from its left are one JFET three legs from its right are the other JFET. Middle leg is tied to the silicon substrate (no connection in this circuit).
Old 8th February 2019, 09:04 AM   #3566
RainfallSky is offline RainfallSky  Russian Federation
RainfallSky's Avatar
Ian
That's not what you asked but avoid this sellers for any electronic components:
littlediode, utsource, polida
Old 8th February 2019, 09:30 AM   #3567
Thanks for all the advise on suppliers etc.
My main worry now is how to desolder the UPA76H. Even with solder braid, I am worried on how to get a 7 legged dual transistor package out without frying it or the board.
Ian
Old 8th February 2019, 12:12 PM   #3568
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Ian
Better try with a desolder pump.
The braid is not good for this operation.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 8th February 2019, 06:06 PM   #3569
After a great deal of fiddling I got the UPA68H out and then tested it to find that J1 was dead, though J2 was ok. So I finally get an answer to the problem :-)
I have a matched quad of 2sk170's (genuine) and its taking all my will power not to fit them! I will try and be patient and wait for the replacement UPA68H
Thank you for all the suggestions and help.
Ian
Old 8th February 2019, 07:36 PM   #3570
transcendent is offline transcendent
What's wrong with 2sk170's ?
Simon
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
Copyright ©1999-2019 diyAudio
