Salas DCG3 preamp (line & headphone)
diyAudio Chief Moderator
Joined 2002
Nice stuff. Lots of work and a good looking outcome. The sadly defunct Selectronic R-Cores are a joy to see.
What mono op-amps? You host dcstb rectification on vertical daughter boards, possibly with de-ring snubber components?
Or is it an electronic bridge? No rail fuses? Let us know how you will like it in the sound system for line and cans. Congratulations.
I have a few of those R-cores from good old times and I must say that they serve me well.
The vertical boards in DCSTB are the rectifiers based on LT4320 a pair of dual mosfets. I started using them a while ago and I am happy with them. Not cheap though.
I haven't tested the trasformer's snubber network yet, but this is possible in this build. All I need is a quick and dirty Cheapmodo build.
Re fusing - I forgot to place them in the design of DCSTB. In fairness, initially I planned to use a different regulators, but realised that DCSTB is so simple to build, so I started with that one. Anyway, when this amp gets its proper enclosure it will get the proper fusing too.
As for the sound, I only managed to listen to it yesterday for an hour or so. The sound does not disappoint! It is really smooth. However it is a different presentation when I compare it with my current headamp. I will need to spend some more time with both :)
Thanks again!
F
Joined 2002
I have a friend with old K701 made in Austria that he likes them only when driven by the DCG3. Finding them too dry on other gear he says. He had brought them over since my prototype DCG3 was in an open case.
Joined 2002
Nice! Same here. I've had my pair for about 12 years. So far I replaced the earpads and changed the regular jack to 4 pin XLR.
I could not agree more about their sound signature. They need a serious amp to produce the full sound.
There is a mellower wider trend still happening on various headphones when on DCG3 but on the 701s its most noticeable was my experience when he tried to demonstrate what he means.
Im going to install my pre to a new case, becouse Im switching my psu from DCBTS to 2xubib 1.3 pairs (not enough room on my current case).
This might be stupid question, but here it goes: Can the heatsinks be too effective for the Ubibs to work as they should? And same question for Dcg-3 board.
My bias is 150mA.
Joined 2002
Dual mono SSLV1.3 vs dual mono DCSTB can give something like 10% better subjective result in a well resolving system. Mainly for better bass and midbass phrasing, also for a bit cleaner and sweeter overall result. Needs of box area occupation and PSUs sinking are substantially more. The law of diminishing returns obviously kicks in. You have to decide if worthwhile.
By the way, a shared between channels mono SSLV1.3 PSU scenario would be a poor idea since DCSTB is dual mono already.
