Pre-amplifier circuit not working despite attempts to fix it
Old 17th July 2016, 09:29 PM   #1
Rudi1441 is offline Rudi1441
Question Pre-amplifier circuit not working despite attempts to fix it
I tried to build a preamp circuit for an electret condenser microphone. I used this schematic.
The problem I have is there is a VERY loud hum that changes frequency when I change the gain in the second stage of the circuit (I switched R5 for a 220k pot) and when I turn the resistance down on that pot, the frequency goes higher and goes above what I can hear when the pot is near 0k.
I used an audio probe to see how far the original signal makes it through the circuit (it makes it to the front of R2, the horrible loud oscillation starts right after R2 and goes louder and softer throughout the rest of the circuit and still sounds the same at the output of the circuit)
I have to mention that I accidentally connected the power supply the wrong way around when I tried it the very first time, and a little smoke came out of the circuit (not sure out of what component) before I realized my mistake
I tried fixing the problem by doing the following:
I changed the electrolytic caps
I cleaned the back of the vero board and all the solder joints.
I re-did every solder joint to make sure none of them are 'cold' connections
I used a wall power supply (properly filtered) and I also tried a fresh battery to eliminate ground loops.
I changed the opamp for a different one to see if that was the problem.
Any idea what could be wrong?
Thanks in advance
Old 17th July 2016, 09:39 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Place a 100uF 16v cap across R7.
That would be a good place to start. There is no stability in the virtual ground connection.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th July 2016, 09:45 PM   #3
Thanks! I will try this and let you know what I find.
Old 17th July 2016, 10:34 PM   #4
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Thanks in advance
Two things:
First, as already mentioned, there should be supply bypass cap across R7.
Second, and more importantly, the minimum supply voltage for the NE5532 is 10 volts (or +/- 5 volts), so 9 volts won't work properly.
If you're using 9 volt batteries, just add another in series for 18 volts.
Mike
Where we have strong emotions, we're liable to fool ourselves...Carl Sagan
They say I'm lazy, but it takes all my time...Joe Walsh (The Musician)
Old 18th July 2016, 02:53 PM   #5
It's working!!! All I had to do was add the 100uF cap as JonSnell suggested. I know the datasheets says there should be a minimum of +-5V going into this opamp, but I've actually used many of them with 9V and they work 100%. Also, a lot of guitar pedals use this opamp while running off 9V supplies, so that doesn't make complete sense to me, but at least it works, so I am happy!!
Old 18th July 2016, 03:35 PM   #6
adason is offline adason  United States
adason's Avatar
there are often two 9 volt batteries...creating +/- 9 volts
Pre-amplifier circuit not working despite attempts to fix itHide this!Advertise here!
Need a working amplifier circuit please help Batson Solid State 31 16th December 2014 06:38 AM
Need a working amplifier circuit please help Batson Solid State 5 20th November 2014 07:36 PM
Alpine MRV-1507 Protection Circuit Fix Therum Car Audio 12 15th April 2011 02:50 AM
coda pre-01 help fix? IMSTOOPID Analog Line Level 0 11th March 2011 01:14 AM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 10:09 PM
Copyright ©1999-2019 diyAudio
