I have a luxman c-02 with weak channel.
Thread Tools
Old 24th November 2015, 02:00 AM   #1
Highfido is offline Highfido  United States
Default I have a luxman c-02 with weak channel.
Preamp with weak output. Somewhat less body and punch. Anyone willing to fix it for pay? I am in Socal. Doesn't need to be speedy.
Let me know. I would even do the work, once you have troubleshat it.
Old 25th November 2015, 08:23 AM   #2
Mooly's Avatar
This is quite an old preamp I think, perhaps you could tell us a bit more about the fault.
1/ Is the fault on one or both channels ?
2/ Describe the fault... is it just low volume or is the tonal balance affected (such as poor bass) ?
3/ Is the fault apparent when using any input.
4/ Is the fault still present for all settings of the tone controls and switches ?
Old 25th November 2015, 09:03 AM   #3
jvhb is offline jvhb  Europe
Yes early 80's vintage, some of the last real Luxman units.
I have had two of those in the last years, and one was still in very good shape, but the other one had been slow cooked from sitting right on top of the matching power amp M-02. Luxman stupidly didn't make the preamp case deep enough for the power amp to stand on top, so most put the pre right on top of the power.. And the M-02 gets pretty hot when working hard!
Anyways, I found many of the capacitors way out of spec, and a few completely dead, and the phono stage looked pretty roasted. My point is that if your C-02 has been sitting on top of the M-02 for 33 years, it will likely need a lot of work. But if not, it could just be some minor thing.
Have you found the schematics online? If not I can post them here if needed..
Edit: A weak channel on old amp is often just due to a worn out volume pot with poor channel balance, and bad connection. So I would check that to start with.
www.audioberg.dk
Last edited by jvhb; 25th November 2015 at 09:07 AM. Reason: Additional information
Old 25th November 2015, 05:18 PM   #4
One channel weak, less midlow. Otherwise good. Output, not input. That is the only symptom.
Old 25th November 2015, 05:21 PM   #5
It was on top of AB amp as far as I know. I don't care about phono. I don't even care about balance. If that helps. I don't care about using the SAME components. I just want it to output equal.
Old 25th November 2015, 05:40 PM   #6
Mooly's Avatar
So if this happens on line level inputs (not phono) then I would look at C206 in the appropriate channel as a first step. Its a bipolar electrolytic however if you can measure and confirm that there is no DC voltage across the cap then you may as test short it out. It appears to be the only electrolytic in the signal path as far as I can see.
Old 25th November 2015, 06:21 PM   #7
anatech is offline anatech  Canada
anatech's Avatar
Hi Highfido,
Sounds like a coupling capacitor, but the whole thing should be looked at. That is a very nice unit. One set of preamp and power amp I've always really liked a lot.
So, where are you so someone close can maybe give you a hand with that? It's good enough equipment that it should be treated well. Not to mention how pretty the set is ...
Consider having the power amplifier gone over before something fails. They are pretty old now, but fixed up they should last years and years.
-Chris.
"Just because you can, doesn't mean you should" my Wife
Old 25th November 2015, 06:58 PM   #8
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
First clean:
- Input selector
- Tape Monitor
- Mono/Stereo switch
- Subsonic switch
- Tone switch
- Bass bust switch
- All pots: Volume. Balance, Bass, Treble.
Old 25th November 2015, 08:24 PM   #9
anatech's Avatar
First clean:
- Input selector
- Tape Monitor
- Subsonic switch
- Tone switch
- Bass bust switch
But be careful what you use for cleaner and don't use too much!!
I still recommend that a good technician does this. It would be a shame to lose a nice component like that.
-Chris
Old 26th November 2015, 04:07 AM   #10
Tried cleaning the switches with Caig. Not good at getting it in.
I didn't test phono lately.
One thing, I added point to point wiring, to add separate RCAs. One track lifted. It was a ground, and so I attached it to the ground next to it on another RCA. They were ganged on others. Are ALL the grounds supposed to be separate?
I am in Garden Grove, calif, in orange county. I WAS using it with a Jeff Rowland Model 5. Now, a Talk Electronics boutique UK thingie.
I was thinking about a passive. But, my Wiring will be 10 feet. Unless I add DAC with enough gain. Is this reasonable? Then use RCA spdif.
I have a luxman c-02 with weak channel.Hide this!Advertise here!
Thread Tools
LUXMAN M-02 drivertransistors Gunnar 1 Solid State 2 15th May 2013 10:50 AM
FS: Luxman M-02 Zedguy Swap Meet 1 7th November 2009 01:32 AM
diagram dml-02 luxman preamplifier rul Solid State 2 22nd October 2009 01:45 AM
Luxman C 02 Roar Malmin Solid State 0 17th May 2009 09:08 AM
luxman M-02 problems roebas Solid State 3 23rd October 2004 06:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
