i go trough the scematic and look over my psb cant find any fault.
i took some pictures.
if someone has any ideas what i can do i would be happy.
ps its the left channal that is low volume, i turn the balance all the way to left to get equal signal...but i cant use tone controll because off the whining noise.
Dont want to intrude on trouble shooting issues but this is the right place to post. Maybe I can help on TS also. Finally got around to putting into proper case. If anyone needs FPD files that work I can supply. I offboarded volume pot and changed lettering from Carls files. Kind of a throwback to the 1U pres from the 80's and 90's
Nice build! No need for me to undock anything without having a motor potDont want to intrude on trouble shooting issues but this is the right place to post. Maybe I can help on TS also. Finally got around to putting into proper case. If anyone needs FPD files that work I can supply. I offboarded volume pot and changed lettering from Carls files. Kind of a throwback to the 1U pres from the 80's and 90's
Thanks I was very much tempted to try those UV printed panels. Guess you could do cool stuff with itHey nice build Zep! I thought it was mine until I looked closer. Cool looking little Zep graphic. I need to come up with something like that for myself.
But, of course: Most of the credits go to Carl for providing the fpd files where 90% of the work is already done.
I know exactly what you meanWhat brand knobs are you using? Never would have thought how much time I would spend looking for knobs.
The volume knob is a Mentor 9900000421250. But take care: I think I used a shorter pot for this one, as the knob can handle 13mm max.
The other knobs: I think they were from eBay. They are like 20mm in both, length and diameter.
Posted by Zep
"No need for me to undock anything without having a motor pot"
Understand. I decided to Offboard to allow bigger volume knob and allow knob to more balance the look of the front panel. Offset right.
The case on the photo above is a different model.Slimline 1U right here from the DIY store. Will have to ship off front and back panels to FPD for machine work.
If you mean the one I used: it's an el cheapo @henri.de, #52-625-00598.The case on the photo above is a different model.
- Analog Line Level
- Doug Self Preamp from Linear Audio #5
