Doug Self Preamp from Linear Audio #5
Old 4th March 2017, 01:59 PM   #661
Eldam is offline Eldam  France
Banned
No as I don't know if Carl is ok for that to be public as it's the shematic of D Self PS ! But it's on the link or the given doc Carl given by PM.
Old 4th March 2017, 02:04 PM   #662
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yes, ok. Thanks
Old 6th March 2017, 03:58 PM   #663
Carl_Huff is offline Carl_Huff  United States
Sorry, but the power supply is not my IP to publish. The power supply is by Doug Self and can be found on page 530 of his book "Small Signal Audio Design". I invite you to buy his book. It's a good one!
Supplemental info was included in the zip file that I sent you when you purchased the PCBs
Best Regards,
Carl Huff
Old 6th March 2017, 04:07 PM   #664
Hi Carl. Understood. I have it, and yes it's a good read, thanks
Old 6th March 2017, 10:59 PM   #665
Banned
Hi Carl,
what is the best choicde according to you for the decoupling caps of the main power supply pcb please: I have the two choices on the BOMs : MKT or ceramic ?
Old 6th March 2017, 11:05 PM   #666
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Could someone tell me the dimensions of the circuit board? We may be making a preamp chassis and want it to fit the maximum number of pre amp designs.
Mark
"The geek shall inherit the earth"
2019 Burning Amp is in S.F. Thread here on diyAudio:
Burning Amp 2019!!!
Old 6th March 2017, 11:09 PM   #667
Dimensions are in post #2
Old 7th March 2017, 03:18 AM   #668
ammel68 is offline ammel68  United States
Banned
Mark
From post 2, "The main PCB measures 260mm wide and 155mm deep."
Old 7th March 2017, 04:57 AM   #669
diyAudio Editor
Variac's Avatar
Thanx Guys
Burning Amp 2019!!!
Old 9th March 2017, 10:00 AM   #670
orreborre is offline orreborre  Sweden
I just finished the power supply to this project, and when I test it unloaded i get different readings on the positive and negative rail.
I get +16.56 V DC and -16.91 V DC at the output. If if I measure directly on the secondarys I get 22.15 V AC on both.
Is it normal to have a difference like this on the positive/negative side or should I worry?
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
