Doug Self Preamp from Linear Audio #5
Old 28th November 2015, 04:50 PM   #211
Carl_Huff is offline Carl_Huff  United States
Default IO Board Detail
Originally Posted by georgebrooke View Post
Hi Carl,
I can see from your photos that on the IO board, on the right side, there is a connector for a 15V supply and below this, to its left, is another connector which is shorted out. Also, the 15V connector appears to be unused. Is this correct or do these connectors have a purpose for some other setup?
George
Hello George,
I have made a revision to the IO board since the initial PICs that are in the first post of this thread. The right side of the PCB that you will receive looks like this ...
The parts shown on the PIC with their values along with the 2 relays, form a 3 second 'delay ON' circuit. Increasing the capacitor size will increase the delay. A 100uF value will 'delay ON' for roughly 5 seconds. The power to the circuit comes in on the ribbon connector cable. The 12 volt regulator knocks down the incoming voltage to the needs of the delay circuit. The terminal block that I have shorted in the PIC is in series with the +V line that feeds that 12 volt regulator. Opening that line with a switch or external relay immediately mutes the preamplifier output.
The delay circuit and the output section that was not included in the Linear Audio article are detailed in the enhanced schematics are in the kit package. I will also be sending them to everyone as an email attachment.
Best Regards,
Carl Huff
Old 30th November 2015, 04:52 AM   #212
Default Doug Self Preamplifier Kit - Supporting Documents
Hello all,
If you purchased a kit you should have received the following in your email ...
#1) A reprint of the Linear Audio article courtesy of Jan Didden and his Linear Audio magazine.
#2) A two sheet printable schematic of the project PCBs that you are receiving.
Note that the circuit as published in Linear Audio #5 did not include an output section or muted ON delay.
Those two items are not described in the Linear Article but are detailed this schematic
#3) BOM for the preamplifier.
#4) Power supply schematic as recommended by Doug Self.
The power supply was lifted from the pages of Doug's 'Small Signal Audio Design' 2nd edition page #712.
#5) BOM for the power supply.
Please let me know if you did not receive any of the above. Any addendum to any of these documents will be noted first in this thread.
Best Regards,
Carl Huff
Old 30th November 2015, 07:15 PM   #213
mik000000 is offline mik000000  Canada
Carl
project looks great. cant wait to get started and thanks for all your efforts.
I looked at the BOM and have a couple of questions.
i cant find the C1,,3,42,43,44 part at Mouser or digikey. you have it as MFR # K101J15COGF53L2
also, some of the item counts seem wrong although i have not checked them against the schematic
R2,4,4,6,28 shows as 4. Should be 5?
R42,45 shows as 1, should be 2?
R24,40 shows as 1, should be 2?
R41,44,49,50 shows as 3, should be 4?
R23,52,54,29 shows as 5, should be 4?
C1,3,42,43,44 shows as 4, should be 5?
thanks again for all your work
Mike
Old 30th November 2015, 07:40 PM   #214
Default Addendum to DSelf Preamp BOM
Originally Posted by mik000000 View Post
Carl
Mike
Good catch Mike!
I expect that the bad numbers for the caps probably come off a bag off parts that I have that Mouser no longer sells. Here is a good alternative.
C1,3,42,43,44 part at Mouser WIMA #FKP2J001001D00KSSD & Mouser Part #505-FKP2100/630/10
An updated DSelf BOM can be found here. The bad parts counts have been revised as well.
https://dl.dropboxusercontent.com/u/...AMP_BOM_01.xls
Best Regards,
Carl Huff
Old 30th November 2015, 07:48 PM   #215
Rick G is offline Rick G  United States
Just an FYI. Change the O to a 0(zero). i.e.: K101J1C0GF53L2 Works as it should. i got all the parts from mouser & Digikey using the BOM as supplied.
Rick
Old 30th November 2015, 07:55 PM   #216
Rick
Aah ...
Evidence of my fat fingers at play! Great, either part works.
Best Regards,
Carl Huff
Old 30th November 2015, 08:29 PM   #217
Rick
you're faster than i am.
Old 30th November 2015, 09:04 PM   #218
Default ** IMPORTANT NOTE **
Something just occurred to me that I need to point out as it is not immediately obvious ...
The BOM is for one channel. The Doug Self Preamplifier is a two channel device. On the PCB a part say C23, is marked on the PCB silkscreen as C23R and C23L. To populate the board you need to order 2 times the number of parts as shown in the BOM. Sorry for not pointing this out sooner.
Best Regards,
Carl Huff
Old 30th November 2015, 09:36 PM   #219
i had not caught that. this does not apply to the LM4562 Op Amps? the 15 quantity on the BOM is for both channels?
Old 30th November 2015, 09:39 PM   #220
Yup, you are correct.
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Copyright ©1999-2019 diyAudio
