Doug Self Preamp from Linear Audio #5
Thread Tools
Old 8th September 2021, 01:30 AM   #1821
glenv6 is online now glenv6  United States
Originally Posted by Carl_Huff View Post
glenv6,
Here is a rear panel layout for a 1U case. I cannot remember who sent it to me, so thank you whoever you are.
Dropbox - REAR_PANEL_1U.fpd - Simplify your life
Thanks Carl!
sound_yourself on Instagram
Old 8th September 2021, 01:32 AM   #1822
Originally Posted by still4given View Post
Appreciate that, thanks!
Old 12th September 2021, 02:44 PM   #1823
Johnny Canuck is offline Johnny Canuck  Canada
Default Enhanced I/O help please
Wondering if anyone else has encountered this or can provide guidance.
I think (?) I have the latest version of Carl's IO board (has the signal diodes on top, just below the relays).
I am consistently getting 14.8 V downstream from the 12V regulator (17V at the input), and just a bit over 15V across the 1N4148.
It seems like the regulator is damaged, but is there anything else to consider before changing it?
Thanks.
Old 13th September 2021, 11:40 AM   #1824
paulf is offline paulf  United Kingdom
Hi Johnny - there was some discussion about the 78L12 possibly being unstable without caps on the input and output side - starting around post #1058, here:
There are some recommendations in the following threads about adding caps, and values to use. I think put the caps from the App note (TI?) on the underside of the board.
PaulF
Old 13th September 2021, 12:43 PM   #1825
Thanks very much Paulf.
I'll check for oscillation - the smd caps look like a simple solution.
Cheers!
Old 13th September 2021, 01:29 PM   #1826
fvzeppelin is offline fvzeppelin  Germany
fvzeppelin's Avatar
Soldering a small tht tantalum on the bottom side is as easy.
Old 13th September 2021, 08:19 PM   #1827
Carl_Huff is offline Carl_Huff  United States
PLEASE NOTE: The latest IO PCBs have a place for a decoupling capacitor. It is circled in red immediately behind the 12 volt regulator.
Best Regards,
Carl Huff
Old 13th September 2021, 08:38 PM   #1828
Cheers!
If it helps, here is the one I used..
TAP226K035CCS
Old 14th September 2021, 01:22 AM   #1829
Thanks fvzeppelin, that's a good idea and easier to find something close to TI's indicated capacitance.
Thanks Carl, my board doesn't have space for a decoupling cap so I guess not quite the latest version.
TAP226K035CCS
Thanks glenv6 - that's a good selection. Question though, is there a reason to use 22 uF rather than 10uF, or did you just have this value in your parts box?
Old 15th September 2021, 02:39 AM   #1830
Just an update - 10uF across the output and 0.1uF across the input and the reg is stable at 11.8 V (happened to have some SMD pieces in my parts box).
Thanks to all for pointing me in the right direction.
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Thread Tools
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 12 19th April 2021 07:43 AM
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
