Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#1591 |
Yup,
I agree. Simple is the right answer.
Best Regards, Carl Huff |
#1592 |
Finally, I have a working micro-controller doing all the remote duties - channel selection, mute, volume (motor pot) and a 3 second delay at startup. For mute and delay startup, I didn't populate any of the circuit on the selector board. I added a wire from the collector of the bottom transistor to the unused pin (#7) on the selector PCB. This is the ground of the output relays which the microcontroller would do the delay startup and mute tasks. For the channel relays, I had a problem since we are switching +12v on the selector PCB. I ended up building a transistor invertor (NOT gate) using NPN followed by a PNP transistor to give full +12v to the relay. If the selector PCB were switching grounds, one transistor or even a ULN2003 could have been used. The mute circuit is a standard NPN transistor driver as we are only switching grounds. For the volume pot, I used a h-bridge to drive it. The microcontroller will be using a separate 5V power.
The source code I modified can be found at : GitHub - gkiranps/gArduinoRemote The program can be modified to be used with any remote you have lying around. I still need to add either a encoder or switches on the panel for source selection. I almost forgot, the preamp sounds great ! Thanks to Doug and Carl for making available such a beautiful design. Thanks, Dinesh |
#1593 |
Hi Dinesh,
thank you for sharing your approach with us! I am sure that both, wiring and the repo will be helpful for many people ![]() Some thoughts (please keep in mind that I'm not a pro):
#1594 |
Are boards available for this?
#1595 |
oodi said "Are boards available for this?"
oodi, Please check your personal messages. I just sent you one.
#1596 |
Bummer.... I was eagerly awating your answer to oodi's question..... ;-)
#1597 |
"Bummer.... I was eagerly awaiting your answer to oodi's question..... "
Ha, ha ... I still have a few. Personal message me if you want the details
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Doug Self's New Preamp Construction and Pictures | redjr | Analogue Source | 190 | 30th May 2018 07:34 AM |
What does preamp PSU oscillation look like for linear regulators? | shredhead | Power Supplies | 59 | 28th March 2015 10:16 PM |
Doug Self Elektor phono preamp: SA1085 substitute? | tcpip | Analogue Source | 9 | 26th September 2013 01:11 PM |
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB | mclsound | Swap Meet | 7 | 26th July 2013 11:10 AM |
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) | nickds1 | Solid State | 4 | 9th November 2006 01:02 PM |
New To Site? | Need Help? |
