Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#1471 |
So Hicoco not sure what your trying to convey? Just bringing attention to a different version?? I want to use Carls for sure. So carl sorry to belabor this but if I order the Slim1U from DIY audio thick faceplate and send to FPD they can do your Front panel 1U V2 and everything will fit correctly?? How does the faceplate bolt up, not seeing the mounting holes. After I get the front figured out I will post separately on the rear. Thanks all.
#1472 |
The rack package that I have here in front of me, the front panel has four recessed phillips head screws at the corners.
Best Regards, Carl Huff |
#1473 |
yes that is what holds the faceplate to the rack but how is the faceplate fixed to the steel 1U enclosure. are there hidden screws are hidden tapped hole on faceplate. the store just doesn't give enough info on the enclosures.
#1474 |
The 4mm front panel has four big flat head screws through the front. The 10mm front panel uses hidden screws from the inside. With all the pots and selector switch it would likely be best to go with the 4mm front panel for this preamp, otherwise there will be lots of machining required to hollow out the inside of the panel.
https://www.vzaudio.com/ |
#1475 |
Very important point. I was thinking the 10mm but your right the shafts will need to stick through. Do they stick through far enough with the 4mm w/o hollowing out anything?
#1476 |
A 4mm panel should leave you about 2.5mm of thread sticking out the front, which should work fine.
#1477 | |
Why ?? because you can't upload file with .fdp on DIYAudio Forum. This is the same pdf file posted by Jwilhelm post #1305 for the rear panel but with fdp extension and this one fit perfectly with RCA and XLR connectors
Every DIYer need Balanced-Unbalanced Audio Input Selector Module |
#1478 |
Ok so I understand now Hicoco. Thank you.
#1479 |
Hicoco,
Those IO panels that you are offering here: Balanced / Unbalanced Audio Input Selector Module from HICOCO on Tindie look to be especially nice. They look to be a worthy addition to this project should someone want more inputs. Where did you find those RCA phono connectors? Those look handy to have on hand for other projects.
#1480 | |
They are from Recherche - Audiophonics
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Doug Self's New Preamp Construction and Pictures | redjr | Analogue Source | 190 | 30th May 2018 07:34 AM |
What does preamp PSU oscillation look like for linear regulators? | shredhead | Power Supplies | 59 | 28th March 2015 10:16 PM |
Doug Self Elektor phono preamp: SA1085 substitute? | tcpip | Analogue Source | 9 | 26th September 2013 01:11 PM |
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB | mclsound | Swap Meet | 7 | 26th July 2013 11:10 AM |
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) | nickds1 | Solid State | 4 | 9th November 2006 01:02 PM |
New To Site? | Need Help? |
