Doug Self Preamp from Linear Audio #5
Old 4th August 2019, 12:33 PM   #1431
redjr is offline redjr  United States
Very nice bk856er. Great job, and excellent detail and apparent build quality. I built the DS pre 2012 that was published in Elektor a few years back. I'm also using the 'blue PCB' PSU in another project.
redjr
Old 4th August 2019, 01:00 PM   #1432
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Thanks. Seems a good option, especially when combined with FPE.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 4th August 2019, 08:35 PM   #1433
bk856er is offline bk856er  United States
bk856er's Avatar
Setup in my system today. All functions appear to be working correctly and it sounds good fed from the gamma-3 DAC via xlr.
My perception is that the "HI FREQ" far right pot functions in the opposite direction of the labeling. I read another report of this in the thread.
No glamour shots here - just a tower of DIY gear (excluding the 14 projects stacked in the garage, lol).
BK
Old 4th August 2019, 08:58 PM   #1434
diyralf is offline diyralf
diyralf's Avatar
BK
Would you introduce these guys to us?
Old 4th August 2019, 09:19 PM   #1435
bk856er's Avatar
DIY gear? On top is a Whammy setup as a preamp, B1 Korg preamp, AMB Gamma-3 DAC and PS, and of course the newest addition the Self/Huff preamp on top of the Oppo. The big DIY amps mostly out of vew are FW M2 and FW VFET. Speakers are SEAS A26. For casual listening I stream a lot of USB digital from the dedicated MacBook Air out to the Gamma-3. Turntable is a Technics 1210GR with AT 740ML MM cartridge and setup on a very solid 15" Rythmik subwoofer (disconnected a long time ago, strictly 2ch now, makes a great table @ 100+ pounds!).
BK
Old 6th August 2019, 02:10 AM   #1436
bk856er's Avatar
Playing tonight and Dire Straits never sounded so good!
Thanks Carl and team for the wonderful project.
BK
Old 6th August 2019, 03:04 AM   #1437
Carl_Huff is offline Carl_Huff  United States
BK
You are welcome! So glad that you had a successful build.
Best Regards,
Carl Huff
Old 6th August 2019, 08:27 AM   #1438
xbitwise is offline xbitwise  Europe
Hi Everyone,
It looks like very interesting project. Are PCBs still available or am I too late?
Best regards,
bitwise
Old 6th August 2019, 05:57 PM   #1439
Originally Posted by xbitwise View Post
Hi Everyone,
Best regards,
bitwise
Please check your private messages. I just sent you one.
Best Regards,
Carl Huff
Old 8th August 2019, 02:04 PM   #1440
tcpip is offline tcpip  India
One basic question to Carl specifically (because he designed the I/O board), and others:
Is it necessary for the designer to decide that inputs 1 and 2 will be balanced, 3 and 4 will be unbalanced, at the time of design? Can't all analog inputs have both balanced and unbalanced sockets, for an amp which has balanced input circuitry? (I understand that this will mean that the relay count will increase, because you'll have to make provisions for double the number of signal lines even for those inputs which the user may have never decided to use balanced.)
But from the point of view of audio quality and just PCB design, is there a problem if we do this? I am seeing a lot of good commercial products which seem to provide both types of connectors on the same inputs, and I'm pretty sure there are no sensors or switches internally which, say, re-route any signal depending on the plug you connect.
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
