Doug Self Preamp from Linear Audio #5
Old 12th July 2019, 05:21 AM   #1401
Hicoco is offline Hicoco  France
Originally Posted by bk856er View Post
24.5V after the rectifiers, 4.1V across R5/6, 1.4V across R9/10.
BK
I just see in my notes that i had the same values, but when i past 200mA with 60R load value, who is the preamp intensity consummation in the positive Rail the tension start to drop to 15V...you should test it to see..
Old 12th July 2019, 05:49 AM   #1402
bk856er is offline bk856er  United States
bk856er's Avatar
My understanding is the load from the preamp is ~150mA. Therefore I am happy with the PS behavior as load tested with 170mA. I will confirm proper output voltage after assembly, and if necessary address any issues at that time.
BK
Old 12th July 2019, 05:59 AM   #1403
BK
Yes you are right for the preamp board, but you have to ad the values of the I/O Board
Old 12th July 2019, 06:28 AM   #1404
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
BK
That's cutting it close. From 24.5 input you need: 2V headroom for the opamp, 4.1V for R5/R6, 1.4V for R9/R10, getting down to 17V. Get a dip in mains and it drops out of regulation.
That R5/R6 is too large and R9/R10 is too small, for me that is a design oversight.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 12th July 2019, 06:35 AM   #1405
bk856er's Avatar
Jan
Understood. I'll grab some of the values you recommended earlier.
BK
Old 12th July 2019, 07:43 AM   #1406
Well done, yes use 47 ohms, or higher, up to 100 ohms should be OK. With 1.2V across the 1k, even 100 ohms only eats 0.12V from your overhead. 100 ohms may be better for stability.
Jan
With 100R for R5/R6 and 1k for R9/R10 with preamp board and I/O board connected for 1h..no overheat and stable at 17V, 200mA for the positive Rail and 150mA for the negative.
Perfect......Thanks a lot Jan
Old 12th July 2019, 08:18 AM   #1407
jan.didden's Avatar
Yes, there should be no difference in dissipation. The dissipation is (Vin-Vout)*Iout and that doesn't change.
Jan
Old 12th July 2019, 08:22 AM   #1408
jan.didden's Avatar
The main reason for that is that the input voltage drops with higher load, and the ripple voltage increases with higher load. Then there is noi enough headroom left for all that other stuff we discussed.
It does also mean that with a larger transformer it may work up to larger loads. Untill your neighbour switches on his sawing machine and the mains drops 10V ;-)
Jan
Old 13th July 2019, 02:43 AM   #1409
bk856er's Avatar
Jan
I replaced R5/R6 with 100ohm and R9/R10 with 1kohm.
Still have stable +/-17V with 170mA load, but now with 0.144V across R5/R6 and 1.41V across R9/R10. Temps are the same.
I had no issues, but made the change on Jan's suggestion as good practice. Thanks everyone for the good discussion!
BK
Old 13th July 2019, 06:35 AM   #1410
diyralf is offline diyralf
diyralf's Avatar
Jan
In the third world, yes, not in the North EU
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
