Doug Self Preamp from Linear Audio #5
Old 14th June 2019, 05:29 AM   #1341
Hicoco is offline Hicoco  France
Originally Posted by diyralf View Post
The NE limit is +-22V. +-15..20V is standard.
That is true, but the problem is that i have +-30Vdc after the rectifiers because of 240Vac here in France and 22Vac at the output of the Transformer for 18Vac with the AMGIS L01-6364.
Carl what do you thing? do you know an equivalent to the NE5534 for 30Vdc and Plus or you do you have an other option?
Old 14th June 2019, 05:52 AM   #1342
Carl_Huff is offline Carl_Huff  United States
Yea, that voltage is much too high. I had thought France had 220v mains. 240v is a surprise to me! Your simplest path would be to swap out the transformer for a lower voltage equivalent. The AMGIS L01-6363 at 15v secondaries or better yet the AMGIS L01-6362 at 12v secondaries would drop in and drop your voltage to the proper levels.
Best Regards,
Carl Huff
Old 14th June 2019, 06:54 AM   #1343
diyralf is offline diyralf
diyralf's Avatar
230V is used in France. With +-10%. --> 253V. Watch out!
Old 14th June 2019, 07:22 AM   #1344
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I agree with Carl. You can swap the opamp with a higher voltage one but performance will suffer.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 14th June 2019, 05:35 PM   #1345
J.M.K is offline J.M.K  France
Hi!
I'm on France too, and was faced with the same issue.
Plus the fact that AC is sometimes very unstable and can jigg from 220 to 260 V in an instant.
Just build another power supply and shoot for 15V.
I also have it in a separate enclosure. and much lower ground noise by the way....
No issue for 4 years, wonderful music.
JM
Old 17th June 2019, 06:07 PM   #1346
bk856er is offline bk856er  United States
bk856er's Avatar
I really look forward to building this preamp. I'll deviate slightly from the BOM and use NP green UES electrolytics only at C2/4 and C45/46. Everywhere else will get Silmic-II. Dale RN55 resistors throughout, my usual go-to part. I've had a bunch of productive email exchanges with Carl. Any builder recommendations and tips appreciated!
BK
Old 19th June 2019, 08:59 AM   #1347
Thanks, with everything connected i have 21.5VAC at secondary and 27.3VCC after the rectifiers for 241VAC at primary
If i do the math with a 12VAC transformer, i should have 20VCC after the rectifiers.
I am surprise that anybody else have this problem..because with a 18Vac at secondary you should have around 23/24VCC after rectifiers, that is to much for the NE5534 !!!!!
Old 19th June 2019, 03:40 PM   #1348
DouglasSelf is offline DouglasSelf  United Kingdom
DouglasSelf's Avatar
I find this conversation puzzling. Surely the voltage after the rectifiers is being applied to the voltage regulators, not the opamps.
You are using a regulated supply, I assume?
Douglas Self
Old 19th June 2019, 04:20 PM   #1349
jwilhelm is offline jwilhelm  Canada
I think he's referring to the op amps in Carl's series regulator supply.
https://www.vzaudio.com/
Old 19th June 2019, 04:22 PM   #1350
I think the op amps are powered rail to ground. NE5534 is rated for maximum 44V V+ to V-.
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Copyright ©1999-2019 diyAudio
