Doug Self Preamp from Linear Audio #5
Old 30th March 2019, 05:26 PM   #1291
Hicoco is online now Hicoco  France
Old 30th March 2019, 05:41 PM   #1292
rsavas is offline rsavas  Canada
Did anyone measure the offset voltages? Since the offsets are so low, I do not think polarity is problem.
When in doubt I use Nichicon UES or film.
DougS has written that he prefers large V and C to minimize the low freq THD in ecaps.
I also read that someone in the forum measured ecap thd on a number of models/brands, the Nichicon Muse BP UES series was the winner, but only marginally.
Old 30th March 2019, 06:15 PM   #1293
diyralf is online now diyralf
diyralf's Avatar
THD is not a function of brand or V.
Old 7th April 2019, 05:23 PM   #1294
Do you know where I could find Amgis L01-6354 or equivalent, Digikey is out of stock thanks.
Old 10th April 2019, 09:58 AM   #1295
hadihf is offline hadihf  Pakistan
Originally Posted by Carl_Huff View Post
That's a really good question that has not been asked before! Orientation didn't matter with the caps that I used, but ...
if you are building with polarized Silmics, I would follow the direction as published in the Linear Audio article.
Pointed out in post #1076
Old 1st May 2019, 02:55 PM   #1296
Originally Posted by Statsokonomen View Post
I also first attempted using Hicoco's version of the back panel, and found that it didn't fit (a few millimeters off on many parts).
I'll measure myself and will order a new back panel from Schaeffer when my measurements are done. If the new panel fits the board, I'll post the Schaeffer / Frontpanel Express file in this thread.
I'm sorry, but I should have advise that I had not used Rick G's post # 876 files yet..
you are right, unfortunately that it don't fit...i am changing right now the measurements...
Carl by any chance, do you have the quad rca phono socket pdf datasheet?
Old 1st May 2019, 03:52 PM   #1297
Carl_Huff is online now Carl_Huff  United States
Sorry, I don't but they are easy enough to measure with a linear caliper. I am not at home right now or I would do it myself.
Best Regards,
Carl Huff
Old 1st May 2019, 04:01 PM   #1298
Thank Karl i appreciate that, i don't have a linear caliper.
Old 1st May 2019, 04:09 PM   #1299
Well, if nobody else responds I will measure them in a couple of days when I have access and opportunity. Are you looking to create a 1U back panel to go with the front panel FPDs that I previously provided?
Best Regards,
Carl Huff
Old 1st May 2019, 04:12 PM   #1300
jwilhelm is offline jwilhelm  Canada
I have this drawn in Fusion. I'll try to put some dimensions together from it.
https://www.vzaudio.com/
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
