Doug Self Preamp from Linear Audio #5
Old 31st December 2018, 05:18 PM   #1261
diyralf is offline diyralf
diyralf's Avatar
Originally Posted by brian92fs View Post
Basic question on gain structure. With the default gain of 10 db, how does this translate to input sensitivity? What is the max input signal that leaves enough headroom to avoid clipping with the 17v power supply? Is this dependent on the crest factor of the source signal?
If the source is unbalanced 2Vrms / 5db, the default 10db gain structure would increase this to unbalanced 6Vrms / 16db at the output. Do I have the math correct?
The op amps can handle max 10V. 10dB means gain of ~3. If you need 1V for your power amp, al least 333mV at input is required.
Old 31st December 2018, 11:15 PM   #1262
brian92fs is online now brian92fs  United States
Thanks! Glad to hear my math is on the right track.
Old 7th January 2019, 10:06 AM   #1263
rock12 is offline rock12  United States
Ordered boards about a half year ago and am now getting to them I noticed my power supply is v1.0 on my earlier build the power supply was v1.0b they are certainly not the same. Can you still order boards?
Old 7th January 2019, 10:11 AM   #1264
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Mixi View Post
That makes perfect sense. Thank you very much!
I believe you can also ask Frontpanel Express to anodize your panels after machining, but there's an extra cost.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 7th January 2019, 03:58 PM   #1265
The re-anodize option for Front Panel Express must be region specific. I asked about this for the US about a year ago and they said they don't offer that service.
Old 7th January 2019, 04:36 PM   #1266
Carl_Huff is offline Carl_Huff  United States
Rock12,
I've already sent you a private message that gives you an URL for the DOCs. I also wanted to let you know that I have power supply PCBs on hand should you want for use in other projects.
Of late I have been shipping a very nice 'old school' series regulated supply PCB as described back on post #1231. This one has the advantage of being easily configurable for 120v or 230v systems.
Best Regards,
Carl Huff
Old 18th January 2019, 01:15 PM   #1267
I have this power supply and I am looking for a BOM?
File Type: jpg 22048208-50A5-4816-8ABE-61CF28294158.jpg (884.9 KB, 331 views)
Old 11th February 2019, 01:25 AM   #1268
hfxrzw is offline hfxrzw  Netherlands
What is needed to change the original power supply from 115V to 230V? I've moved from the USA to Australia and need to make the change. Thanks, Rene
Old 11th February 2019, 02:17 AM   #1269
rsavas is offline rsavas  Canada
Looking at thread #1, see the blue transformer, it has the wiring on top, it shows two primary windings @115V each. you are to wire the primaries in parallel for 115V ( connect the 2 dots) and in series for 230V (connect the non-dot to the dot).
Old 11th February 2019, 03:26 AM   #1270
Cheers for that, understood, but as the unit is soldered to the PCB I hoped to hear if I can just cut a lead or add a bridge to the PCB to make this work.
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
