Doug Self Preamp from Linear Audio #5
Old 1st November 2018, 08:17 PM   #1241
Carl_Huff is online now Carl_Huff  United States
Originally Posted by asuslover View Post
Which of these 2 power supplies has lower noise?
thanks
I presume that you are asking about V1 (LM337/ LM317) as compared to V2 which is an 'old school' series regulated design. Both are very good and very quiet and exceed the capabilities of my humble bench gear. I invite others to chime in, but ...
I expect that V2 might have a slight performance edge on V1.
Best Regards,
Carl Huff
Old 4th November 2018, 07:58 PM   #1242
DoubleIPA is offline DoubleIPA  New Zealand
Originally Posted by Carl_Huff View Post
I use the M3 threaded nylon hex standoffs. They can be purchased everywhere.
Ebay is an especially good source. Amazon works too.
Is a 6-6 mm standoff high enough?
Old 5th November 2018, 01:36 AM   #1243
It depends on the enclosure that you are mounting the board in. For 1U chassis I use M3 x 6mm threaded HEX standoffs.
That standoff is approximately 1/4 inch tall. I buy them on EBay.
Best Regards,
Carl Huff
Old 5th November 2018, 02:37 AM   #1244
Thanks for your help, forgot to mention that previously.
I am looking at a modushop 2U Slim Line case, but planned to have the tone controls setup like the 1U and the selector and volume with larger nobs raised and spaced outward a bit. I suppose I should lay it out before I order the standoff's. I planned to use the template as the base for the the layout and wasn't sure if they were adjusted for standoffs or not.
Old 7th November 2018, 04:27 PM   #1245
tomi2251 is offline tomi2251  Norway
hi guys
its seams to be alot of changes in layout and BOM
its a little tricky to find witch BOM i going to use, since i have preamp V2.1b
can any one tell me so i can buy the right things? please.
Tomi
Old 7th November 2018, 06:44 PM   #1246
Originally Posted by tomi2251 View Post
hi guys
The schematic and basic layout has not changed since the beginning.
PCB v2x spread the front panel controls a bit per request of builders.
Please check your private messages. I just sent you a link to the latest DOCs.
Best Regards,
Carl Huff
Old 7th November 2018, 07:33 PM   #1247
fvzeppelin is offline fvzeppelin  Germany
fvzeppelin's Avatar
hi guys
I would per default replace the 3.3k resistors by 1k to set overall gain to unity. But in the end this depends on your needs.
Old 17th November 2018, 08:09 PM   #1248
Funkel Trumpet is offline Funkel Trumpet  United Kingdom
Default Doug Self Pre Amp
Hi Carl. I built the original precision pre amp in 1996. It was featured in Wireless World as a series of articles. Loved the tone controls, very good at controlling a booming base. Is it still possible to order the set of boards plus any other components that come with them.
Many thanks.
Old 18th November 2018, 05:12 PM   #1249
Many thanks.
This project is based upon the Doug Self article entitled, "A low-noise preamplifier with variable-frequency tone controls" that was published in Vol 5 of Jan Didden's excellent Linear Audio magazine. The important details of the project are all contained in that article.
I still have a few kits available. Please send me a personal message if you are interested if you are interested in acquiring one or more of them.
Best Regards,
Carl Huff
Old 25th November 2018, 03:16 PM   #1250
fvzeppelin's Avatar
Does anyone have fpd files for the back panel? Just in case...
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
