Doug Self Preamp from Linear Audio #5
Old 25th October 2018, 05:26 PM   #1231
Carl_Huff is offline Carl_Huff  United States
Originally Posted by Hicoco View Post
Hi Carl,
I just saw that you did not send the Adjust Power Supply board but the Fixed Power supply PCB, but i do not understand because there are the label "ADJ PWR SUPPLY" printed on it, see pictures
The bubbles at the top are the rail voltage adjustment pots and the large bubble at the bottom is where you select input AC voltage. Once assembled you will have a premium grade series regulated adjustable power supply
Best Regards,
Carl Huff
Old 25th October 2018, 05:38 PM   #1232
Hicoco is offline Hicoco  France
Yes i got this PCB, but unfortunately i got all my component for the other one.....i followed this adjust power supply schematic.
Could you post the new schematic and boom list thanks
File Type: jpg KAD_ADJ_PWR_SUPPLY_SCHEMATIC_REVISED.jpg (149.7 KB, 408 views)
Old 25th October 2018, 06:10 PM   #1233
Aah, okay. That is because per your request, we sent you our power supply PCB that easily adjusts from 120v to 230v inputs. The version that you were expecting does not support that easy change. In any case the good news is that they share many parts in common.
Here is the schematic and BOM for the power supply that we shipped you.
File Type: pdf SERIES_REGULATED_PWR_SUPPLY_SCHEMATIC.pdf (186.1 KB, 81 views)
Best Regards,
Carl Huff
Old 25th October 2018, 06:41 PM   #1234
Rick G is offline Rick G  United States
Carl,
is it possible to 1 of this Regulated PWR Board.?
If so i would like to purchase 1.
Rick G
Old 25th October 2018, 06:52 PM   #1235
Originally Posted by Rick G View Post
Carl,
Rick G
Sure,
For people within the US we can do ...
1 PCB for $10 (including the cost to ship) or ...
3 PCB for $20 (including the cost to ship)
Simply message me should you want to proceed.
The cost of shipping would a bit higher for those outside the US but we try to keep that reasonable as well.
Best Regards,
Carl Huff
Old 25th October 2018, 09:36 PM   #1236
diyralf is offline diyralf
diyralf's Avatar
Be aware. These op amp supplies are not short circuit protected.
Old 1st November 2018, 01:25 AM   #1237
DoubleIPA is offline DoubleIPA  New Zealand
Default Standoff/riser question
I'm in the process of procuring a case for the Self preamp and was wondering what you all use for standoff's or risers?
Peter
Old 1st November 2018, 07:48 PM   #1238
fvzeppelin is offline fvzeppelin  Germany
fvzeppelin's Avatar
I'd be interested in recommendations, too.
Peter
Old 1st November 2018, 08:03 PM   #1239
Peter
I use the M3 threaded nylon hex standoffs. They can be purchased everywhere.
Ebay is an especially good source. Amazon works too.
Best Regards,
Carl Huff
Old 1st November 2018, 08:54 PM   #1240
asuslover is offline asuslover  Romania
Which of these 2 power supplies has lower noise?
thanks
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Copyright ©1999-2019 diyAudio
