Doug Self Preamp from Linear Audio #5
Old 17th October 2018, 05:06 AM   #1221
DoubleIPA is offline DoubleIPA  New Zealand
Anyone have suitable replacement for xicon 140-50U5-473M-RC (47n Ceramic Capacitor 50V) from digikey or mouser? This is for the power supply.
I wasn't sure how to use their search engine to find a replacement and everything that came up was rather different.
On digikey the LM7915CTFS-ND is obsolete and the replacement MC7915CTGOS-ND and LM7815ACT-ND replacement is MC7815ACTGOS-ND.
Old 17th October 2018, 08:07 AM   #1222
Hicoco is offline Hicoco  France
look @ FG26C0G1H473JNT6 Mouser should work
Old 17th October 2018, 09:47 PM   #1223
Thank you!
Old 18th October 2018, 05:49 PM   #1224
Carl_Huff is offline Carl_Huff  United States
Default Project Updates: IO & Power Supply PCBs
Originally Posted by Carl_Huff View Post
... In any case it is a reasonable thing and I will add a part pad to the IO PCB. Thank you for sharing!
Changes ...
IO PCB: Per my previous commitment I have added a capacitor pad to output of the 12v regulator that powers the relays. I have also added support for alternate grounding schemes for the XLR connectors. As a builder you must now either add a wire jumper to the system ground or to the chassis as is pro audio practice. The inputs are grounded separate from the outputs. You must properly terminate both the input XLRs and the output XLRs. If you fail to do that ground will float unterminated.
Pwr Supply PCB: I am now shipping the revised boards that include jumpers allowing the builder to configure for either 120v or 230v AC systems.
Best Regards,
Carl Huff
Old 18th October 2018, 06:17 PM   #1225
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by batteryman View Post
At last my order of 4k7 pots arrived so can get on with the build
CPC still have 90 in stock.
https://cpc.farnell.com/omeg/pc2g16e...4k7/dp/RE04429
I used those, very nice pots, pins required slight bending, but worked well.
Old 19th October 2018, 12:48 AM   #1226
Changes ...
Thanks Carl for your continued work.
I'll don't have all my parts yet, but I'll be doing a little head scratching with 230V. I'll be sure to post once I get started.
Old 21st October 2018, 02:49 PM   #1227
batteryman is offline batteryman  United Kingdom
Yes, I was surprised that the front/rear pin spacing was a bit out. I assumed standard spacing, but it was not an issue. I didn't feel confident in the quality of the Alps clones given the very low cost but I have used Omegs before with no issues.
Old 25th October 2018, 04:04 PM   #1228
Hi Carl,
Just got my boards today, looks very nice... i saw that you have added a diode pad for each relay...cool do not have to solder it behind the PCB.
By the way what is the suggest capacitor and is value that you have added to output of the 12v regulator that powers the relays.
Thanks Click the image to open in full size.
Old 25th October 2018, 05:04 PM   #1229
Yup, that's it minus the Lorlin front panel switch. Mouser stocks them now.
Hi Carl,
I just saw that you did not send the Adjust Power Supply board but the Fixed Power supply PCB, but i do not understand because there are the label "ADJ PWR SUPPLY" printed on it, see pictures
Old 25th October 2018, 05:06 PM   #1230
Hi Carl,
The pad added to the output of the 12v regulator is intended to accept a tantalum 10uF to 22uF capacitor. It most likely will not be required but is harmless in any case. Enjoy!
NOTE: Don't forget to ground the XLRs on the revised IO board.
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Copyright ©1999-2019 diyAudio
