Doug Self Preamp from Linear Audio #5
Old 5th October 2018, 10:16 PM   #1191
Hicoco is offline Hicoco  France
Originally Posted by Carl_Huff View Post
What do you think of this?? Does that work for you?
Aah, okay. That will delay your order 10 to 14 days as I will need to send that out for fab. I have no problem with that as I had planned on stocking them anyway. Just note that your shipment will be delayed.
this is fine, no rush thanks
Old 6th October 2018, 08:57 PM   #1192
Hi, Carl
Is it the latest version ?
Old 6th October 2018, 09:30 PM   #1193
fvzeppelin is offline fvzeppelin  Germany
fvzeppelin's Avatar
Originally Posted by batteryman View Post
I looked at several types but couldn't find one that fitted so bought the recommended one.
If you do the 115/230 mod, I'll buy a couple more pcbs for other projects.
Attached Vigortronix data - mains pins and pin spacing generally all completely different.
A little late, but the Talema 70054K is compatible, e.g. here:
TALEMA Ringkern-Print-Transformatoren nicht kurzschlussfest Leistung: 15VA Eingangsspannung: 2x115V
Old 6th October 2018, 09:47 PM   #1194
DoubleIPA is offline DoubleIPA  New Zealand
Is this the same or suitable replacement for CK05BX100K? The appear to be the same or similar on paper.
CK05BX100KPDIP AVX | Mouser New Zealand
Old 6th October 2018, 10:05 PM   #1195
Hi, did you find your ribbon cable?
Old 6th October 2018, 10:14 PM   #1196
I found ribbon cable on arrow. I also found it on Amazon.
Old 6th October 2018, 10:35 PM   #1197
could you please post the link in Amazon, i have a hard time to find it
Old 6th October 2018, 10:42 PM   #1198
Hope this helps. I ended up ordering from Arrow. I had everything shipped to a friend in Texas to cut down on shipping costs.
Amazon.com: 20 pin ribbon cable
Old 6th October 2018, 11:08 PM   #1199
Thanks, this is Amazon USA and they don't have it here in Amazon France.
Old 7th October 2018, 04:47 AM   #1200
Carl_Huff is offline Carl_Huff  United States
Hi, Carl
Yup, that's it minus the Lorlin front panel switch. Mouser stocks them now.
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Copyright ©1999-2019 diyAudio
