Doug Self Preamp from Linear Audio #5
Old 5th October 2018, 12:07 AM   #1181
DoubleIPA is offline DoubleIPA  New Zealand
BD Enterprises was great until shipping and the cheapest they'd do for $5.71 worth of product is $72. Will try to ship it to a friend in the USA and have them ship it over.
Old 5th October 2018, 04:52 PM   #1182
Hicoco is offline Hicoco  France
Hi Carl,
Is The power supply PCB that you sent is the last PCB fully adjustable ? Because I don't have the BOM in the package you sent, i have the no adjustable Power Supply BOM (SERIES VREG_FIXED_PWR_SUPPLY.zip)
Old 5th October 2018, 05:00 PM   #1183
Carl_Huff is offline Carl_Huff  United States
Originally Posted by Hicoco View Post
Hi Carl,
Some builders were struggling with the 'adjustable' nature of the power supply. Some to the point of blowing up op amps with over voltage. As result I began shipping a fixed voltage version. The voltage out is determined by a resistor pair.
Best Regards,
Carl Huff
Old 5th October 2018, 05:24 PM   #1184
Thank Carl, i saw also some post with builders complaining and asking for adjustable because there was different voltage between + and -.
is it to late because i prefer adjustable?? i also asked for the last version!!!!!!
Old 5th October 2018, 05:50 PM   #1185
The fixed voltage reg supply that I have been supplying of late is an 'old school' series regulated design that is much tighter as to output voltage. The voltage out can be changed using a different resistor pair. However if you want the pot adjustable version please let me know quickly as your package is ready to ship and I would need to swap out the PCB.
Best Regards,
Carl Huff
Old 5th October 2018, 07:08 PM   #1186
i really appreciate Carl, i am sure the Fixed Voltage reg is very tight as to output voltage. i also prefer to have the freedom to adjust the voltage without desoldering the resistors.
Please i will really appreciate that you dispatch the package with the adjustable voltage PCB.
Old 5th October 2018, 07:17 PM   #1187
... Please i will really appreciate that you dispatch the package with the adjustable voltage PCB.
Not a problem. I will make the swap.
Best Regards,
Carl Huff
Old 5th October 2018, 07:22 PM   #1188
thank you
Old 5th October 2018, 08:53 PM   #1189
What do you think of this?? Does that work for you?
https://www.diyaudio.com/forums/atta...jumpers_00-jpg
Carl, again thank for your help, i would like also check with you about this PCB and be sure that you will sent this one with 230V, yes we have also 230V/240V here in France
Old 5th October 2018, 09:07 PM   #1190
Aah, okay. That will delay your order 10 to 14 days as I will need to send that out for fab. I have no problem with that as I had planned on stocking them anyway. Just note that your shipment will be delayed.
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
