Doug Self Preamp from Linear Audio #5
Old 1st October 2018, 11:30 PM   #1161
Freecrowder is offline Freecrowder  United States
One other thing square solder pad on IDC connector is pin 1 correct.
Old 1st October 2018, 11:46 PM   #1162
Carl_Huff is online now Carl_Huff  United States
Default IO Switch Assembly Details in PICs
The Lorlin switch is adjustable as to the number of selector stops by simply moving the washer under the nut that has a 'finger' reaching into the switch body. That finger becomes a physical stop for the switch.
Sorry about your frustration. The attached PICs should clarify your assembly issues.
Best Regards,
Carl Huff
Old 2nd October 2018, 01:36 AM   #1163
I fixed some issues with IDC not lining up with pin 1. So far I have inputs 3 and 5 working. I have not tried XLR's yet. Still don't understand switching yet. The position on switch are farther apart than expect to see. Too many switch positions between 3 and 5. Your board for switch is a different version than mine. A little bit confusing. to get pin one on IDC and the board pin 1 you have to put switch on side that says to put it on the opposite side. Do you have any more switch boards. May have messed something up on the board from solder -desolder. frustrated and calling it a nite.
Old 2nd October 2018, 02:03 AM   #1164
Originally Posted by Freecrowder View Post
... Do you have any more switch boards. May have messed something up on the board from solder -desolder. frustrated and calling it a nite.
Sure, we can fix you up. Please send me a private message and we will get your problems sorted.
Best Regards,
Carl Huff
Old 2nd October 2018, 03:52 AM   #1165
DoubleIPA is offline DoubleIPA  New Zealand
Default Great thread
I really enjoyed reading through this thread. What a fantastic project.
Some of the cases were amazing. I thought the wood versions were quite special.
Cheers!
Peter
Old 2nd October 2018, 10:07 AM   #1166
hadihf is offline hadihf  Pakistan
Default I/O board schematic
Carl, if its OK with you I can share my schematic of I/O board which is an exact replica? pdf file.
Best Regards
Farooq
Old 2nd October 2018, 01:50 PM   #1167
If Carl doesn't mind I would like to have that I/O schematic for troubleshooting.
Old 2nd October 2018, 02:13 PM   #1168
Best Regards
Farooq
Sure,
Please post it.
Best Regards,
Carl Huff
Old 3rd October 2018, 05:49 AM   #1169
Anyone using a potentiometer with a center detent for balance and tone controls? Does this one look like a possible match?
5k ohm Dual Linear Rotary Potentiometer with Center Detent
Old 3rd October 2018, 06:33 AM   #1170
That looks to be a great choice!
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 12:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Copyright ©1999-2019 diyAudio
