Doug Self Preamp from Linear Audio #5
Thread Tools
Old 31st January 2018, 09:28 AM   #1001
R.I.P.
Originally Posted by brian92fs View Post
Question on variable gain - would it be practical to connect the pads for R42 and R45 to a switch that allows 2 or more discrete values to be selected? For example, going to a toggle switch that allows 0 db or 10 db gain to be selected? Or would the length of the wires going to the switch compromise performance?
switchable gain is possible.
One should check that stability margins do not change adversely at some of the options.
Switching a gain stage to unity gain gives no useful advantage. It would be better to either switch select to a buffer stage or bypass and go completely passive if the source can drive the resulting capacitances.
regards Andrew T.
Old 19th February 2018, 08:12 PM   #1002
Mixi is offline Mixi  Europe
does anyone know what the values for input & output impedance are?
will the performance of the amp be affected if the gain is lowered or set to 0 ?
Old 2nd March 2018, 09:11 AM   #1003
JohnWalker is offline JohnWalker
does anyone have the backpanel (1U format) of these amp in the 'panel designer format' or in DXF-format available for me ?
kind regards,
John
Old 2nd April 2018, 12:55 PM   #1004
hadihf is offline hadihf  Pakistan
Will a 5k log pot for volume work OK?
Farooq
Old 2nd April 2018, 01:23 PM   #1005
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The volume control circuit functions logarithmically with a linear potentiometer, why do you want to use a log pot?
Old 2nd April 2018, 04:37 PM   #1006
Carl_Huff is offline Carl_Huff  United States
Farooq
Nope sorry Farooq. It's got to be a 5K dual linear pot. A log pot will not work.
Best Regards,
Carl Huff
Old 2nd April 2018, 04:59 PM   #1007
Thanks Carl...I am still in collecting parts phase...found a good quality pot but it is a log type.
Old 2nd April 2018, 05:11 PM   #1008
You may find more options if you use 4.7k ohm pots
Old 2nd April 2018, 05:39 PM   #1009
Default 5k pot
Page 33 of DS book...Self on Audio.. made me think otherwise but I might be missing something.
"It can be readily shown by simple algebra that the control track resistance now has no effect on the gain law, and hence the channel balance of such a system depends only on the mechanical alignment of the two halves of a dual linear pot."
Old 2nd April 2018, 08:47 PM   #1010
asuslover is offline asuslover  Romania
Where can I get a stereo set for this preamp?
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Thread Tools
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 12 19th April 2021 07:43 AM
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
