BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Old 17th July 2019, 03:38 PM   #811
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I think the power supply requirement is in the article, and iirc +/-22V at 1A is more than enough. But check to be sure; +/-22V may actually be a bit high for dissipation in the local regulators, depending on which ones you use.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 17th July 2019, 04:22 PM   #812
La 67 is offline La 67  Spain
Thank you Jan.
I did read the article but only found reference to the Hypex regulators. I plan to use them in my build.
Old 17th July 2019, 05:12 PM   #813
jan.didden's Avatar
Probably need to check the max dissipation on the Hypex data sheet. If you have 22V in, 12 volts out, and say 100mA current draw, your dissipation V*I for those regs is (22-12)*0.1=1W.
If that is too high, you can for instance put a 4.7V zener in series with the reg input to absorb some voltage, and with that part of the dissipation (which now is in the zener of course).
Jan
Old 17th July 2019, 05:16 PM   #814
jan.didden's Avatar
LMGTFY.
DIYclassd.com
1W is just on the edge. I wouldn't live there.
Jan
Old 17th July 2019, 05:18 PM   #815
jan.didden's Avatar
Or use one of my SilentSwitchers, mains free, can run from a USB charger/port or a Powerbank.
Overall cheaper even I think compared to 2 Hypex regs and the primary supply.
Jan
Old 17th July 2019, 05:56 PM   #816
trung224 is offline trung224
Hi Jan,
How does your SilentSwitchers compare to Jung/Didden Regulator in terms of noise and output impedance?
Could I use 6,6V battery with it to create +- 12V for this preamp?
Thanks in advance.
Old 17th July 2019, 06:18 PM   #817
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
It was a noticeable improvement feeding +/- 15dc straight to the caps after the rectifier vs ac.
Old 17th July 2019, 07:10 PM   #818
jan.didden's Avatar
Originally Posted by trung224 View Post
Hi Jan,
Thanks in advance.
Yes 6.6 input works fine. Max current at +/-15 is 150mA, at +/-12 about 180. Should be enough for Bruno's preamp.
Quality is very close to superreg, probably bit lower noise, bit higher Zout. But all the numbers are very low anyway.
Jan
Old 17th July 2019, 07:40 PM   #819
I could imagine that as it could reduce the pulse current of diode, when switching, to ground of signal path.
What regulator do you use in your BPPBP?
Old 17th July 2019, 09:19 PM   #820
@jan.didden
Thank you for your answer. I received the BPPBP board last week, and now need to decide which power supply and potentionmeter to use for this project.
Today, I find a schematic for one PSU, which was called GRLV and developed by Kevin Gilmore based on Walt Jung's design.
I would be very grateful if someone with deep knowledge like you could comment some opinion about it
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)Hide this!Advertise here!
Bruno Putzey interview Zero D Solid State 5 30th May 2014 12:29 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Preamp with discrete solid state volume control. Dave Solid State 6 20th August 2004 09:17 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
Copyright ©1999-2019 diyAudio
