BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Old 1st January 2019, 10:11 PM   #751
NATDBERG is offline NATDBERG  United Kingdom
Originally Posted by sq225917 View Post
Nat, enlarge those holes or redo the back panel, that tension in the back panel pcb is trouble down the line.
You're probably right !
I intend on making another (I've corrected the CAD) to make two pre-amps so the other will be ok.
I think I'd have to cut the panel in two to remove the extra 2 mm from between those connectors else widening holes will have to be done to all holes to one side of the mistake. I'll make a jig for a multi-tool to keep it straight and bond something to the rear after..
Old 3rd January 2019, 05:33 PM   #752
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
I bypassed the 3 pin power input and diodes today and wired my dc supply directly to the caps. Worked perfectly.
Now I'm totally baffled, dc wouldn't work into the 3 pin plug, but a.c. did. WTH?
Paradise Pre-reg PSU PCBs
Old 4th January 2019, 02:40 PM   #753
Martant is offline Martant  Finland
Originally Posted by stephengrenfell View Post
I don't need the other 9 PCBs and they might be useful to someone. Therefore I am offering them at 3euro each plus postage (using standard letter post only).
Hi all BPPBP preamp builders,
I wonder if stephengrenfell or somebody else has still any leftover PCBs for sale. If so, please contact me by personal message.
Martti
Old 10th January 2019, 05:38 PM   #754
Turns out my distortion was from choking the dc voltage to 14.3 volts. 15.2v and it's gone.
Old 22nd January 2019, 08:02 PM   #755
maartn is offline maartn  Netherlands
One more question on parts: the BOM I used lists U3 as TI LM4562MA/NOPB (same as U1, 2, 6, 7) with the remark: "TL072 (as originally proposed) has a DC offset that is way too large and is adding offset of its own."
Is that correct? Is LM4562MA/NOPB the right part to use for U3?
Old 22nd January 2019, 08:26 PM   #756
misterdog is offline misterdog  United Kingdom
yes,
Old 10th February 2019, 07:43 PM   #757
I desoldered the oversized caps and put right ones in... This pre-amp does sound really good!
One thing I noticed is quite a loud "pop" at shutdown. I measured at the output and there is a 600 mV negative spike on pin 2 (see attached screenshot). I had not expected that, because I thought relay K3 is there to prevent this kind of thing (see attached detail of the circuit).
Do other people also see/hear this behaviour, or is there something wrong with my build?
Old 10th February 2019, 09:09 PM   #758
Hans Polak is offline Hans Polak  Netherlands
Plop on both channels or just one channel ?
And why is the red channel, the power supply, only 8 volt, assuming a 10:1 probe.
I doubt whether your reley is working properly given the timescale that you are showing.
Hans
Old 11th February 2019, 06:06 PM   #759
Hi Hans, it is on both channels. The voltage axis of the red channel is displayed on the right of the chart: 16 volt.
I do hear the relay click and checked with a multimeter just now: the resistance between pins 2 and 3 is ~2 ohms at power off, and ~46 ohms at power on. Not sure if these values are as they should be, but it does look like the relay is at least operating. I will try coming weekend to measure the timing of the relay switching, relative to the power down. Any other suggestions are welcome.
Old 11th February 2019, 06:41 PM   #760
I see your problem.
Instead of +/- 12Volt you are using+/-16 volt. Nothing wrong with that but the zener should then be 26 volt instead of 18 volt. The transistor is now driven into hard saturation with a base current of ca 6mA instead of 2mA.
Instead of the zener, you could change the 2k2 into 6k8, and you could also lower the lower resistor into 1K.
Hans
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)Hide this!Advertise here!
Bruno Putzey interview Zero D Solid State 5 30th May 2014 12:29 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Preamp with discrete solid state volume control. Dave Solid State 6 20th August 2004 09:17 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
Copyright ©1999-2019 diyAudio
