BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Old 15th November 2018, 09:06 AM   #741
NATDBERG is offline NATDBERG  United Kingdom
And my 6 input back-panel for Quad FM4 cases should arrive today too! Only 2 years since I got my bpbbp parts..
Old 15th November 2018, 09:41 PM   #742
Yay! Back panel for the 6- input board looks good!
Boo! Somehow I managed to make a mistake and added an extra 2mm between two of the XLR holes.
Still fits, just with a small bend.
Old 22nd December 2018, 08:07 AM   #743
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Quick question for you gents.
My BPBP worked fine on a +/-/0v 15 volt feed, then I cased it all up and now the positive reg doesn't light up with the same dc feed, but it works fine on a +12/0v-12v a.c. feed.
Any suggestions before I crack her open. All connection via same 3 pin terminal block. I've tried all possible dc+12v input options on that 3 pin block and none work.
I'd think a fried rectifier but they must work as they rectify the a.c....
Weird huh.
Paradise Pre-reg PSU PCBs
Old 22nd December 2018, 08:35 AM   #744
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by sq225917 View Post
a +/-/0v 15 ... +12/0v-12v a.c. feed.
Is the different order on the above voltage series just sloppy writing or is that really different? If the latter, that may explain it maybe?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 22nd December 2018, 09:28 PM   #745
Just sloppy writing,I've actually tried plus and minus 15 dc on either side. Only the negative reg ever powers up on dc. On a.c. they both work.
Old 31st December 2018, 05:19 PM   #746
maartn is offline maartn  Netherlands
Originally Posted by maartn View Post
I am using the BOM linked on this page
One more caveat with this BOM: after ordering from Mouser I found that some of the caps are larger than intended (see pic). I must have missed something, but the part numbers are the same or very similar.
Old 1st January 2019, 09:55 AM   #747
Eh, those aren't the parts from the bom we all used. Who's bom was it?
Smart move with the reg mounting, wish I'd thought of that.
Old 1st January 2019, 02:43 PM   #748
Ah... Unfortunately, one always needs to check through the thread to double check no problems with the BOM. A shame it wasn't updated!
When I ordered my parts (I used the list and recommendations in the original thread), I also double checked the size and pitch before ordering.. There was a problem with the original BOM too I seem to remember but people's own discoveries warned future DIYers.. Picking out capacitors can be a real pain when you have to juggle so many paramaters! Always puts me off ordering parts.
Here is a correction to it: Bruno Putzeys Balanced Preamp - Group Buy Part 3, Page 17
Old 1st January 2019, 02:49 PM   #749
Nat, enlarge those holes or redo the back panel, that tension in the back panel pcb is trouble down the line.
Old 1st January 2019, 07:38 PM   #750
For the record: I used the BOM linked on the first page of GB3, hoping it had been updated... But NATDBERG is right, I should have read down the thread. Hopefully the final parts (MILF resistors on back order) will arrive this week and I'll be able to finish the thing and test it.
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)Hide this!Advertise here!
Bruno Putzey interview Zero D Solid State 5 30th May 2014 12:29 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Preamp with discrete solid state volume control. Dave Solid State 6 20th August 2004 09:17 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
Copyright ©1999-2019 diyAudio
