Arduino based LDR volume and source selection controller
Old 14th February 2017, 10:31 PM   #651
cdsgames is offline cdsgames  Canada
Whats the latest precision ..at 10k can it do 1% of target LDR resistance ?
Old 15th February 2017, 08:06 AM   #652
zdr is offline zdr  Belgium
zdr's Avatar
5LN01C might also become obsolete soon, so I was looking for alternatives. This one might be it:
https://www.fairchildsemi.com/datasheets/FD/FDV301N.pdf
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 15th February 2017, 12:49 PM   #653
rbalu72 is offline rbalu72  India
How about 2N7000, its thru whole, relatively low VGS(th) but different pin ?
Old 15th February 2017, 02:36 PM   #654
savvas is offline savvas  Greece
Originally Posted by Vincent77 View Post
Talking about the precision: the controller can approach the target LDR resistance within 0.1% at 1K, 1.5% at 10K and 5% at 50K
At first page of the thread Vincent stated the above about target resistance
Old 15th February 2017, 02:39 PM   #655
Well Mouser stock over 8k of them, I certainly hope not
Old 15th February 2017, 02:40 PM   #656
zdr's Avatar
It was 5k stock at mouser for 5ln01sp a month ago too...
Sent from my MI 5s using Tapatalk
Old 15th February 2017, 02:49 PM   #657
Yeap I read that, I was thinking that those numbers improved in subsequent revisions. A 10k stepped attenuator it is observed that best clarity of sound stage is usually at 0.1% or better 0.01% .
I am not trying to criticize this project that was made available so graciously by Vincent just thinking on how to improve such LDR attenuator.
Old 15th February 2017, 07:26 PM   #658
garym999 is offline garym999  United Kingdom
Thanks to Vincent77 & an AIW board purchased from ZDR. I now have this all up and running on the bench. What a brill project
I spent a while trying to debug Error 20 but this ended up being a mis-soldered connection to one of the mosfets cos of the SOT footprint and me soldering them to a board designed for thier descrete counterparts.
I used ZDR's modded code so I could use an OLED display. It is one of the 0.96" ones that I had from another project but I'm planning to go for a larger white one.
Is there anyway to get the volume bar to redraw correctly on fast updates (rotations) of the encoder? At the moment if I'm too heavy handed with the knob the bar breaks up.
I need to spend time looking at the code because I'd like to make the maintenace menu less prominent. Maybe make the "Exit"option selected by default for a quick exit or make the menu only available with a long press etc. Just thinking out aloud.
Old 15th February 2017, 08:15 PM   #659
zdr's Avatar
I'm sure there is, I just didn't have time and motivation to fiddle with it. I would rather solve the audible volume "bump" first.
Old 15th February 2017, 08:33 PM   #660
zdr's Avatar
Originally Posted by wineds View Post
Neb, Have a look at getAttFromStep (around line 980). There is a potential discontinuity at 40% of the number of steps you have nominated. Also see post #64.
I only now went about checking this. I don't think it's a problem anywhere in calibration, as static values are spot on. Problem is dynamic transition from step A to step B - volume drops for a fraction of a second, then quickly settles back right where it should be. Maybe culprit is switching from low current to high current mode (and vice versa)?
Arduino based LDR volume and source selection controllerHide this!Advertise here!
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 09:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 10:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
Copyright ©1999-2019 diyAudio
