Arduino based LDR volume and source selection controller
Old 11th January 2019, 10:16 PM   #1151
xbitwise is offline xbitwise  Europe
Hi zdr,
Are you still selling LDR kits or just AIO PCBs?
I would be very interested in buying one.
xbitwise
Old 11th January 2019, 10:18 PM   #1152
zdr is offline zdr  Belgium
zdr's Avatar
Yes, PM me.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 14th January 2019, 07:29 PM   #1153
r100 is offline r100
Default Working well
Hi, a quick note to report back on my experience after a couple of weeks with the VxD volume controller v 2.6 in my main system.
Output is to Peter Daniel Gainclone amplifier, input is from a Allo Kali / Piano2.1 DAC fed by a 320 kbs Spotify stream. Speakers are KEF LS50's.
Safe to say that the sound I'm getting from this set-up is the best I have been able to obtain so far. It is very airy and transparent with silky tight deep bass and beautiful rendition of instruments and voices. I can listen for hours on end working or doing other things and really liking the enveloping effect of the music. When sitting close to the speakers (they are monitors after all), its almost like having a pair of very good headphones on and the spaciousness of the sound is fantastic.
The user interface, remote control and calibration of the LDR's are also very cool.
So, thank you to all involved (especially Neb) in the creation, tuning and optimisation of this great volume controller :-)
Old 14th January 2019, 07:44 PM   #1154
zdr's Avatar
Very glad you like it. You should move to the next level and replace gainclone with Roender’s FC100.
Old 17th January 2019, 08:35 AM   #1155
Looks like an interesting project but I’ll enjoy the absence of updatonitice for a while longer :-) it’s feels so good !!!
Old 26th January 2019, 09:35 AM   #1156
Does this amp use a lot of electricity when idle / running ? I've tried to avoid amps that heat the room while idle :-)
Old 29th January 2019, 08:33 PM   #1157
i mean the FC100
Old 30th January 2019, 07:55 AM   #1158
zdr's Avatar
Originally Posted by r100 View Post
i mean the FC100
RMI-FC100 is class A until 8W so there is some heat dissipated, but it can be biased for less dissipation. Better to ask for details in the FC100 thread.
Old 1st February 2019, 05:47 PM   #1159
rpafenberg is offline rpafenberg  United States
zdr,
Purchased your v2.2z version board recently and tried hooking it up today. I am getting a error 20. According to the trouble shooting section, this is related to the power supply voltages. After double checking that the proper voltages are getting to the controller board connectors, I was wondering if I might have missed a jumper on this new board that incorporates locations for it's own power supply components?
Is that the problem or is there anything else I should be looking for?
Roy
Old 1st February 2019, 06:02 PM   #1160
zdr's Avatar
There are no jumpers to be set, board is backwards compatible out of the box. Error 20 means relay power failure or ldr failure (resistance > 200 ohm)
Arduino based LDR volume and source selection controllerHide this!Advertise here!
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 09:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 10:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
Copyright ©1999-2019 diyAudio
