Arduino based LDR volume and source selection controller
Old 9th December 2018, 08:28 AM   #1131
zdr is offline zdr  Belgium
zdr's Avatar
I figured out why latest Arduino IDE breaks IR - it's the timing in newPulseIn function:
return clockCyclesToMicroseconds(width * 29 + 16);
this line needs to be changed to:
return clockCyclesToMicroseconds(width * 22 + 16);
Repeat will still not work after this, so further changes to be made are these:
//if (duration == 0) // This is an error no start or end of pulse
// return (255); // Use 255 as Error
if (repeat && (c4 == 2) or repeat && (c4 == 1)) // Only way to verify a repeat from this remote is with the 2 code?
Now we can all switch to latest IDE.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 9th December 2018, 04:09 PM   #1132
t-minik is offline t-minik  France
You made an awesome work on that project zdr.
Thanks a lot.
I use it for a few month now and I can say it's very convenient to use.
Old 9th December 2018, 04:12 PM   #1133
SpyNet is offline SpyNet  Greece
Have you corrected at your google drive shared files?
Old 9th December 2018, 04:28 PM   #1134
zdr's Avatar
So far only VxD_OLED1602_4X2 has been corrected.
Old 9th December 2018, 08:43 PM   #1135
wineds is offline wineds  Australia
Looks like some of my hacks @zdr?
Old 9th December 2018, 09:01 PM   #1136
zdr's Avatar
No idea, did I step on parts of your code?
Old 9th December 2018, 09:31 PM   #1137
I recall having to hack those bits for a different IDE version when I first built it. I recall using a 1khz square wave to try and recalibrate the software based timing code. The repeat code was also troublesome and was based on codes returned by the remote in debug mode. A weakness of this design is that the remote code is not interrupt driven.
Old 10th December 2018, 07:30 PM   #1138
yurgs is offline yurgs
Hey there,
here is another casing option for the LDR controler, i put it i an old Tuner Case and i think it fits quite well.
might not be for everyone but i like the "classic" look.
The big knob drives the encoder (and still the tuning bar )
The fm mode Button does the same thing as pushing the encoder.
i dont seem to be able to find how to dim the display, i used the latest 4x2s code.
And there is a font included in the file, modern_h which only cosists of numbers, does anyone have the matching (size24x32) letters?
Thanks!
Lenco L75/ Jelco 750L/ Denon DL103 Shibata // Hypnotoad's AD797 Pre // LDR Arduino Controller // chocoholic's Liteamp // Prestigeous 2 Monitor
Old 11th December 2018, 01:08 PM   #1139
zdr's Avatar
Originally Posted by yurgs View Post
Hey there,
Thanks!
NICE! No letters, sorry.
Old 11th December 2018, 01:27 PM   #1140
Thanks Neb!
the extra size of the tuner case also allows me to put the crossover and my two Sub-Amps in there.
The Letters are not really that important, just a nice to have...
I wanted to use Kapital letters instead of the input number. like PC,BT,
I also tried to include Fonts from the Adafruit_GFX.h Library, but thats above my skill level with arduino.
Do you have an idea why my Display is not fading?
it always stays lit fully, i used your latest code for Oled_4x2s, the Display is same as the one you posted earlier in this thread. IDE is 1.6.9, but my board is not your newest V3, i got the "previous" Rev.
You put an amzing amout of work into this!
Thanks again for all your help!
J
Arduino based LDR volume and source selection controllerHide this!Advertise here!
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 09:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 10:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
Copyright ©1999-2019 diyAudio
