Arduino based LDR volume and source selection controller
Old 18th October 2018, 07:23 PM   #1091
Blamm is offline Blamm  Netherlands
Most people here build this as a separate preamp, with its own power supply and housing. I am considering building it and integrating it into a case with the TPA3118 boards I already have running.
These run on a 24V power supply like these. Instead of creating the supply mentioned by Vincent here, would it be a terrible impact on performance to fork the needed voltages off this supply using a couple of those cheap and simple adjustable step-down converters?
Old 18th October 2018, 07:25 PM   #1092
zdr is online now zdr  Belgium
zdr's Avatar
As long as the power is stable and clean, there should be no impact imho.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 18th October 2018, 07:46 PM   #1093
Yeah I think that's the case. Might just give it a go, worst case I can build a new power supply for it all
Old 19th October 2018, 01:52 AM   #1094
wineds is offline wineds  Australia
I think you could fork the 12v analog ok but I would keep the digital and relay supplies separate. In the original power supply design both these supplies come from a separate transformer winding.
Old 19th October 2018, 04:58 AM   #1095
Note also that the reservoir capacitor for the +8V digital rail (C3 in original design) is important in terms of power down detection and saving of program variables to non volatile memory.
Old 19th October 2018, 07:02 PM   #1096
Thanks, the buffer op 8V is something to keep in mind indeed! Could be added of course.
Separating the 12V lines properly, to avoid interference I presume, might be more tricky without double windings. A couple of diodes might not fix that.
Guess it's not really worth the effort in that case. Might as well just build the second supply for the preamp.
Old 27th October 2018, 12:07 PM   #1097
yurgs is offline yurgs
Hello,
there are 2 different versions of the firmaware in the shared folder,
VxD OLED 4x2 and VxD OLED 4x2s
do you mind sharing what the difference is?
Lenco L75/ Jelco 750L/ Denon DL103 Shibata // Hypnotoad's AD797 Pre // LDR Arduino Controller // chocoholic's Liteamp // Prestigeous 2 Monitor
Old 27th October 2018, 12:10 PM   #1098
zdr's Avatar
S stands for screen saver. The one without s doesn’t have screen saver routine.
Old 27th October 2018, 02:09 PM   #1099
Default Subwoofer Output
Thanks Neb,
i updated my device with the new code,
but i was also wondering if it is possible to change the function of the output relays slightly:
(using the LDR to switch my Subwoofer output (Relay6) on and off.)
If "Output1" is selectet i would like to switch on R5, and if "Output2 is selectet i would like to switch on both, Relay5 and Relay6.
do you think this works?
Old 27th October 2018, 02:12 PM   #1100
zdr's Avatar
Originally Posted by yurgs View Post
Thanks Neb,
There is no problem to make it work from the arduino point of view. You need to make sure it works from electrical perspective, as the load impedance will go down when you drive two inputs.
Arduino based LDR volume and source selection controllerHide this!Advertise here!
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 09:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 10:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
