Arduino based LDR volume and source selection controller
Old 12th October 2018, 05:19 AM   #1081
zdr is offline zdr  Belgium
zdr's Avatar
SMD version is stil available plus there is fdv301n.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 13th October 2018, 05:12 PM   #1082
t-minik is offline t-minik  France
Hi all
just a question , do we need to disconnect all input and output devices before calibrating or it can remains connected ?
best regards.
Old 13th October 2018, 05:24 PM   #1083
zdr's Avatar
I think the latest firmware will mute the outputs but will not disconnect the active input. You can simply switch to unused input or disconnect active one.
Old 13th October 2018, 10:45 PM   #1084
Ok thanks zdr.
it seems bias fluctuating a bit with time , do you recommend to let an "heat up" time (eg:15min) before calibrating ?
best regards.
Old 14th October 2018, 02:25 PM   #1085
xmerlin is offline xmerlin  Italy
I've already printed the PCB , do you have any suggestion for a replacement with the same SC-72-3 package?
thanks
Christian
Old 14th October 2018, 02:36 PM   #1086
SpyNet is offline SpyNet  Greece
You can try these adapters
10pcs Double-Side SMD SOT23-3 to DIP SIP3 Adapter PCB Board DIY Converter HT | eBay
Old 14th October 2018, 02:37 PM   #1087
Originally Posted by SpyNet View Post
thanks!
Old 15th October 2018, 04:09 AM   #1088
zdr's Avatar
Originally Posted by t-minik View Post
Ok thanks zdr.
best regards.
That would be recommended, yes.
Old 16th October 2018, 08:15 PM   #1089
Project16 is offline Project16  France
Project16's Avatar
thanks
Christian
You can also do like me.
Old 16th October 2018, 08:22 PM   #1090
jsantoro is offline jsantoro  United States
Or like me:
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 08:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 09:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 10:51 AM
LDR Based Input Selection udailey Analog Line Level 25 5th October 2011 10:03 PM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 01:50 AM
