Arduino based LDR volume and source selection controller
Old 19th September 2018, 04:45 PM   #1071
zdr is offline zdr  Belgium
zdr's Avatar
I have another finished set for sale, pm me if interested.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 22nd September 2018, 12:26 AM   #1072
zdr's Avatar
I found few serious bugs in the code:
1: If you set a volume in upper half and try to set bias, you will notice that lower LDRs (shunts) are way off. It's because the upper half of the volume values set LDRs range to high, causing shunt resistance to fail to be set properly. Workaround is to do bias setting with volume below 20. Fix will be to set the volume to 0 when entering setup menu, and to restore on exit.
2: Power off detect routine triggers saving of IO values into EEPROM. If you play trigger happy with power switch, not only that values might not get saved, it erases the whole EEPROM, and sometimes, even the whole program memory. It happened as often as in 1 attempt out of 10, on two different boards. I'm not sure if this is a problem with some Atmel batch, but I will kill this routine anyway and save values when screensaver kicks in instead. I will also try to rotate EEPROM address locations for IO and volume, to prolong it's lifespan.
Old 22nd September 2018, 10:04 AM   #1073
nori1000 is offline nori1000  Austria
I understand this correctly, if I use the VxD_OLED_5x2 I can use the board for 5 inputs, but which is the fifth input?
Old 30th September 2018, 05:35 PM   #1074
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
Gents, hoping to get back into hobby after long break.
I have Versatile and comfortable passive pre-amp ldr assembled and tested.
Can anybody give me quick heads up hpow different two approaches are and whether arduino based one is better or not.
Thank you.
How to find time to finish my projects ?
Old 30th September 2018, 05:50 PM   #1075
voxxonline's Avatar
And another one. For guys who use myref fremen with ldr and dcg3, what is the point of dcg3 in this chain?
Old 30th September 2018, 09:28 PM   #1076
zdr's Avatar
I haven't tried the other one, but it seems to be based either on motor pot or lightspeed attenuator which requires painful manual LDR matching. Nuff said.
Old 30th September 2018, 09:34 PM   #1077
voxxonline's Avatar
It does. However I have mine assembled, just looking out for any fresh flavours
Old 1st October 2018, 06:54 AM   #1078
zdr's Avatar
I don't even know how lightspeed maintains the LDR current and resistance. VxD runs in constant loop to maintain the LDR resistance constant.
Old 1st October 2018, 07:42 AM   #1079
voxxonline's Avatar
No idea how it implemented technically. Works well though
Old 12th October 2018, 02:37 AM   #1080
xmerlin is offline xmerlin  Italy
5LN01SP-AC looks discontinued, do you have found any replacement?
Arduino based LDR volume and source selection controllerHide this!Advertise here!
LDR Based Input Selection udailey Analog Line Level 27 8th November 2018 04:37 PM
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 09:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 10:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 11:51 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 02:50 AM
