noisy pre amp, audio transformer noisy?
Old 12th August 2015, 06:12 PM   #1
31474 is offline 31474  Canada
Default noisy pre amp, audio transformer noisy?
Hi guys,
i normaly hang out in the solid state amplifier forum, this is my first post in here!
i have a BAE 1073MP pre amp with a noise problem and i think i have narrowed it down to a noisy audio transformer.
the transformer itself is a carnhill transformers vtb9045.
it makes noise regardless of if theres a input device or not
it seems to be too sensible to outside disturbance.
if i tap the transformer with a pen, i can hear it on the output.
if i tap the transformer with my finger i can hear it on the output.
and of course its sensible to electric interference if i bring the power supply next to it.
im wondering if its normal for an audio transformer to be so succeptible to outside disturbance?
it seems a transformer is around 120$ for me to aquire. would it be worth it to replace it with the same thing?
thank you for your input guys.
Old 12th August 2015, 06:52 PM   #2
R.I.P.
Swap transformers between the two channels.
What happens ?
rgds, sreten.
Old 12th August 2015, 06:53 PM   #3
simon7000 is offline simon7000  United States
Originally Posted by Salomon102 View Post
Hi guys,
These are the classic signs of a low level audio transformer someone checked for continuity with an ohmmeter. Remove the transformer from the circuit and run an AC current through it. Use a 47 ohm resistor and a signal generator set for about 25 hertz. Start at around 5 volts and over the course of an hour reduce this to zero volts. That should mostly fix the transformer. Either that or blow it open! If you think it is too small to take 100 mA start with 1 volt. Try it out and if it isn't healed try a bit more voltage.
Now that should cover mechanical noise, electrical pick up requires a shielded enclosure. So be sure you have a decent case for the gizmo.
Old 12th August 2015, 07:00 PM   #4
id be curious to know how passing ac will fix it.
is it because the winding moves around and sets itself?
Sent from my SM-G920W8 using Tapatalk
Old 12th August 2015, 07:05 PM   #5
What happens ?
rgds, sreten.
this unit only has a single channel
Old 12th August 2015, 07:53 PM   #6
No it demagnetizes the core.
  Reply to this post
noisy pre amp, audio transformer noisy?Hide this!Advertise here!
Noisy transformer akis Power Supplies 42 22nd October 2012 10:44 AM
Very noisy pre-amp outputs. jaimegmr Analog Line Level 4 9th February 2011 11:34 PM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Cambridge Audio Azur 540A amp noisy (50Hz?) tja Solid State 0 16th January 2005 11:47 PM
Noisy Transformer pinkmouse Parts 3 4th July 2002 05:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
