XLR to RCA adapter causes gross amounts of distortion...
Thread Tools
Old 5th June 2015, 09:12 PM   #1
shredhead is offline shredhead  United States
shredhead's Avatar
Default XLR to RCA adapter causes gross amounts of distortion...
Hi everyone,
I've always heard that when making an adapter that goes from XLR to RCA, you the standard way of wiring it is to tie pins 1(ground) and 3(cold) together like this: How to Wire an XLR to an RCA Connector
When using such an adapter though, it limits the maximum output of the preamp by almost a third.
This attached picture shows the maximum voltage out of the hot(pin 2) line without the adapter and then with the adapter. The adapter that ties pins 1 and 3 together causes a lot of distortion past ~6Vpk.
Does anyone know why this is the common way to adapt XLR to RCA if it causes this problem?
Old 5th June 2015, 10:02 PM   #2
MarcelvdG is offline MarcelvdG  Netherlands
Connecting a balanced source to an unbalanced input is always a bit tricky. Whether pin 3 should be grounded or left open depends on whether the source has a high or a low common-mode output impedance.
Old 5th June 2015, 10:10 PM   #3
R.I.P.
AFAIK its the other way round, 1 & 3 together for RCA to XLR.
Shorting an active output is always a bad idea, leave 3 open.
rgds, sreten.
Old 5th June 2015, 11:19 PM   #4
It depends on the whether the source is more or less floating (high common-mode output impedance, for example a transformer-coupled output) or not (low common-mode output impedance, for example two amplifier stages driven in antiphase, one of which drives pin 2 and the other pin 3).
With a source with floating output you need to ground pin 3 to stop the source from floating. When it doesn't float in the first place, you have to keep pin 3 open to ensure you don't short circuit anything.
Old 6th June 2015, 12:57 AM   #5
shredhead's Avatar
Say we're talking about an 8pin dual package op amp with 2 inverting buffers to get the hot and cold out. There is an AC coupling cap and then 100 ohm resistor to isolate the op amp from the capacitance of the output cable.
Is leaving one side of the op amp floating bad in this case?
Wouldn't it make more sense for the adapter and put a load resistor between pins 1 and 3 so the output amp isn't floating anymore if this is a bad thing?
I guess because this thing is distorting badly with pin 1 and 3 tied together it's common-mode output impedance is high?
Would it make sense to put a resistor load from pin 3 to ground then?
Old 6th June 2015, 04:06 AM   #6
Davey is offline Davey  United States
rgds, sreten.
Some professional equipment is setup (on purpose) such that providing a pin 1-3 short on the output increases the gain available on pin 2. (The Behringer equipment for example.) However, I agree that it's probably preferable to not have the pin 1-3 connection.
Shredhead, I would perform surgery on your adaptors to remove the pin 1-3 connection. That will most likely eliminate your distortion. If you have enough gain then you're all set. Limiting your preamp maximum output is not necessarily a bad thing. This "floating" output on pin 3 will not be an issue at all.
FYI, a lot of source equipment with balanced XLR outputs doesn't even have signal on pin 3. Just a resistor to ground with a value equivalent to the source resistance on pin 2 to create the balanced source impedance.
Dave.
Old 6th June 2015, 05:37 AM   #7
In this case I'd leave pin 3 open. Both op-amps produce a voltage referred to ground, so it doesn't float with respect to ground (not at the signal frequencies, that is).
Old 6th June 2015, 09:07 AM   #8
DF96 is offline DF96  England
R.I.P.
There ought to be a sticky somewhere about the difference between a balanced output and a biphase output. This issue keeps coming up.
Old 6th June 2015, 09:13 AM   #9
R.I.P.
.................I've always heard that when making an adapter that goes from XLR to RCA, you the standard way of wiring it is to tie pins 1(ground) and 3(cold) together like this: How to Wire an XLR to an RCA Connector................
No, Pin1 goes to Chassis. that will be at the XLR end of your interconnect cable.
Pins 2 & 3 are the Signal Pins.
There will be a voltage difference (the Signal voltage) between Pin2 and Pin3. Your Receiver will read this voltage DIFFERENCE and amplify it.
But there is the Balanced impedance source to be checked.
Will it accept connecting Pin3 to Audio Ground in the Receiver?
Most Balanced Impedance Sources will accept this connection (Pin3 to unbalanced Audio Ground).
regards Andrew T.
Old 6th June 2015, 09:46 AM   #10
R.I.P.
Pin 1 Revisited
Sound System Interconnection
see 1, 2, 5, 6, 7, 8, 11, 12, 13, 14, 17, 18 and 23 all show balanced to unbalanced and all show the shield connected to chassis at the balanced end.
All show the shield NOT connected to either of the the signal wires at any end.
regards Andrew T.
XLR to RCA adapter causes gross amounts of distortion...Hide this!Advertise here!
Thread Tools
Can a XLR to RCA adapter ruin an equipment ? ginetto61 Construction Tips 12 16th May 2015 07:06 PM
4 pins Mini XLR to dual 3 pins XLR adapter. eduardokbb Construction Tips 4 19th August 2014 05:40 PM
XLR balanced to camcorder input adapter yesiam Solid State 0 13th April 2011 09:25 PM
XLR Adapter Box Schematic S816Freak Parts 1 18th February 2005 05:49 PM
XLR 4pin to 3 pin male adapter kevinhero Parts 3 18th November 2003 01:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
