This is high quality low pass filter for subwoofer for best bass response to your audio system.It uses 4558 opamp ic for its operation.It has volume control,bass boost control and frequency control pot for best results.The power supply required is dual power supply of +/- 12V.The pin no. 8 of IC 4558 is connected +12v and pin no. 4 of IC 4558 is connected to -12v of power supply.The switch SW201 in scematic is for changing the phase to achieve accurate bass in listening postion.It also has Hi level inputs facility to take source signal from another audio amp.
check out this thread:This is high quality low pass filter for subwoofer for best bass response to your audio system.It uses 4558 opamp ic for its operation.It has volume control,bass boost control and frequency control pot for best results.The power supply required is dual power supply of +/- 12V.The pin no. 8 of IC 4558 is connected +12v and pin no. 4 of IC 4558 is connected to -12v of power supply.The switch SW201 in scematic is for changing the phase to achieve accurate bass in listening postion.It also has Hi level inputs facility to take source signal from another audio amp.
http://www.diyaudio.com/forums/analog-line-level/268053-low-pass-filter-subwoofer.html#post4225961
Heyy, Check Out this 4558 Subwoofer Booster
or you can check this Subwoofer 4558Heyy, Check Out this 4558 Subwoofer Booster
