Simple discrete unity gain buffer
Old 16th October 2018, 06:40 AM   #131
bimo is offline bimo  Indonesia
bimo's Avatar
Originally Posted by bimo View Post
Diamond Buffer with output cascode.
R24 should 100R and R5 500R trimpot.
#Perkutut#Emprit#GagakHitam#Elang#Pelatuk#Colibri# Blameless100#Blameless150#Blameless1200#AX14Mod#FX 8Mod#AX11Mod#LM1875InvertingWithBuffer#LM3886Inter tingWithBufferAndDCServo#more...
Old 16th October 2018, 07:08 AM   #132
donovas is offline donovas  South Korea
Calvin, i just really like the sound of the buffer 128. it's very musical which i suspect is because of bootstrap feedback. because of this i'd like to explore the circuit more. no doubt your circuit sounds supreme but positive feedback always holds a magical appeal to me.
Old 17th October 2018, 06:02 AM   #133
Calvin is offline Calvin  Germany
Calvin's Avatar
hey, nothing to excuse for You
I just wondered, because You mentioned that the CFP-Buffer īd be beyond Your skills .... while it indeed is no more complicated than the other buffers.
jauuu
Calvin
ps. thanks btw. for assuming my buffer to be supreme
Old 23rd October 2018, 12:26 PM   #134
maouna is offline maouna  Greece
I did an ac analysis for the elector buffer in LTSpice and there is a huge peak in the transfer function.how can this be cured?
Old 23rd October 2018, 01:17 PM   #135
bimo's Avatar
Add bandwidth limiting at the cascode transistor.
Old 23rd October 2018, 01:44 PM   #136
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by donovas View Post
how strong is this buffer btw? im wanting to see if i can drive my sennheiser 600 with it. its 300ohm impedance.
Theoretically speaking, the distortion will climb as the buffer finds it has to drive a lower impedance, even 300 Ohm is more trouble than if using the buffer as a pre-amp driving the input stage of a power amp. But doesn't mean that it won't sound very good. So did you try this yet ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 2nd November 2018, 05:06 AM   #137
bimo, would it be possible to see that in jpeg format? i can't open that file. thank you.
Old 2nd November 2018, 07:21 AM   #138
bimo's Avatar
Old 6th November 2018, 07:40 AM   #139
Calvin's Avatar
did You consider using LEDs (red) instead of R11, R12 and couple them thermally to the NPNs to achieve higher thermal stability of the ccs?
And in using one of the LEDs as kind of preregulator for the second LED the ccs achieved far higher dynamic output impedance.
jauu
Calvin
Old 17th November 2018, 08:09 PM   #140
so once again, its this circuit
how can i bias this higher? do i change the bottom resistor 1.5k ohm and the top resistor 15k to lower values?
and is the input resistor necessary if you're not putting a pot before it?
um, i'd like to ask again, how can i bias this circuit higher? just change all the resistors to lower value?
Simple discrete unity gain bufferHide this!Advertise here!
Simple Line Level Mixer (Unity Gain) Noumenon Parts 3 30th December 2008 12:34 AM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 10:02 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 10:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 11:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
