Simple discrete unity gain buffer
Old 7th June 2007, 10:33 AM   #111
nikwal is offline nikwal  Sweden
Made a low voltage buffer with a depletion mode fet (bsp135 if I remeber correctly) just the fet and a resistor.. That worked nicely but it wasnt hifi-critical at that point.. If I'd do it now I'd try maybe irf610 and 9610 in some kind of diamond complementary design or whatever it's called.. (I made such a thing, but had no use for it so i dont know irl how it would sound, only through the function generator and scope, and spice of course it was nice..
Old 7th June 2007, 06:55 PM   #112
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by routhun
Thanks lineup for the JFET BOZ.
Routhun
thanks for your thank
and .. no problem, because:
this is what I am here for, routhun
* here - in exsistense, in life, living for
... a social animal lives not solo
... a social human will support others,
... his 'friends'
... his social group & so, his Own environment of Living & survival
lineup
lineup
Old 29th September 2018, 03:46 AM   #113
donovas is offline donovas  South Korea
i p2p'd this and it sounds marvelous. probably the best i've heard for the parts count that it has. is 10uf the positive feedback? and can i increase it for more bass?
Old 29th September 2018, 06:08 AM   #114
gannaji is offline gannaji  India
gannaji's Avatar
Dear Donovas,
Can you kindly specify the actual circuit you used ?
gannaji
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 29th September 2018, 10:18 AM   #115
Its the one on post 81. Regards,
Old 29th September 2018, 12:58 PM   #116
gannaji's Avatar
Thank you !
Old 29th September 2018, 04:50 PM   #117
so once again, its this circuit
how can i bias this higher? do i change the bottom resistor 1.5k ohm and the top resistor 15k to lower values?
and is the input resistor necessary if you're not putting a pot before it?
Old 29th September 2018, 06:34 PM   #118
p.s. this circuit has a nasty turn on thump... what would be the cause of this?
Old 30th September 2018, 12:27 AM   #119
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Most SE Class A amps will have a turn on thump. There are a few ways to prevent it. 1) use a cap multiplier on the supply to slowly ramp up the voltage over 10seconds. Something like this (has a 4v dropout penalty though); 2) use a relay with time delay circuit either RC constant or microcontroller.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th September 2018, 05:30 AM   #120
Xr971, i do use that cX, but mine the voltage comes up rather fast?
Ah so the buffers class a. No wonder i like the sound so much. Do u perhaps have any other 0gain circuits i can compare to?
Simple discrete unity gain bufferHide this!Advertise here!
Simple Line Level Mixer (Unity Gain) Noumenon Parts 3 30th December 2008 12:34 AM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 10:02 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 10:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 11:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
