R-2R attenuator PCB layout question
Old 9th July 2018, 03:28 PM   #101
OlegSh is offline OlegSh
I think yes, we need external diodes across the relay power pins. It makes the loop created by back EMF current much smaller which helps avoiding clicks during relay switching. I use diodes with Vf significantly smaller than 0.6V of the diodes built into the ULN2803A. In addition using low Vf diodes can help keeping the relays closed for a bit longer helping to control ON/OFF timing difference (approaching make-before-break effect), which again helps to avoid pops and clicks when adjusting the volume. The last point does not apply to my later design since there the reverse is needed, longer switch ON and shorter release time to achieve the same effect.
Oleg
R-2R attenuator PCB layout questionHide this!Advertise here!
New project : R-2R Attenuator With Remote Control V2 bbp Swap Meet 179 15th November 2015 05:43 PM
amplifier PCB, question on overall grounding layout 00940 Solid State 28 28th September 2013 12:15 AM
Help with 6-Bit R-2R Relay Attenuator benproiii Analog Line Level 1 17th December 2012 05:58 PM
FS - R-2R Attenuator With Remote Control V2 Guiness Swap Meet 3 23rd November 2012 11:07 PM
UcD700 PCB Layout Question Randy Knutson Class D 7 19th June 2006 08:46 PM
