Pop/click free HW-based relay attenuator
Old 18th April 2014, 09:29 AM   #11
Neutrality is offline Neutrality  Denmark
Originally Posted by syklab View Post
How many pub I need for 2 channel?
You need 1 PCB for 2 Channels.
Old 18th April 2014, 09:33 AM   #12
Those SMd part doesn't look that bad.
Some of the parts are really small, however with some skill and patience it can be done.
I did mine without using a microscope and then I used a small loupe to check for solder bridges.
Patience is the key.
Old 18th April 2014, 09:38 AM   #13
poldus is offline poldus  Europe
poldus's Avatar
I would like to buy one board. What is the supply voltage?
Old 18th April 2014, 09:59 AM   #14
12 Volt DC.
Old 18th April 2014, 10:53 AM   #15
syklab is offline syklab  United States
Hi Neutrality,
One dumb question, how do you dial the volume on this attenuator module?
Old 18th April 2014, 11:24 AM   #16
Hi Neutrality,
You just connect a 10-50k linear potentiometer to the molex header marked "pot" and then you just use it as a normal volume control.
The potentiometer puts out a voltage between 0(max attenuation) and 5V(Min attenuation. That voltage is read by an ADC that converts it to a binary value which is then used to control the relais.
So you not only get the smooth feeling of turning a normal potentiometer, like in a normal volume control, but you also get the very accurate channel matching from max to min attenuation, low noise, low distortion that you typically get from a relay attenuator.
Old 18th April 2014, 01:59 PM   #17
For those who want a PCB, see my first post.
Old 18th April 2014, 06:44 PM   #18
This is a picture showing where that extra 1uF cap mentioned in post 1 should be placed.
Old 20th April 2014, 11:00 AM   #19
Here is an updated RAB V1 - BOM - Mouser with the extra 1uF cap added.
Top component placement and orientation.
Bottom component placement and orientation.
Old 20th April 2014, 09:34 PM   #20
cliffforrest is offline cliffforrest  United Kingdom
How do you ensure it is monotonic?
Pop/click free HW-based relay attenuatorHide this!Advertise here!
FS: Relay based stepped attenuator Earfanatic Swap Meet 7 22nd April 2013 03:08 PM
Switching "click" of VPI HW-19 TT bigpandahk Analogue Source 6 24th February 2012 01:45 PM
Click and Pop TDA2050 32W Amp MjWasHere Class D 0 22nd August 2011 04:20 PM
irs2092 click and pop suppressor not working. nigelwright7557 Class D 3 4th December 2010 01:35 PM
relay based attenuator squadra Solid State 21 1st December 2004 11:10 PM
Copyright ©1999-2019 diyAudio
