The Kuartlotron - keantoken's simple error-correction superbuffer
Old 3rd January 2020, 03:28 AM   #961
qq33006498 is offline qq33006498
Hello @ keantoken, I have adjusted the TP terminal to half of the positive voltage, R1 and R2 are 56R, when using Onsemibc550c/560c, the output voltage can not be adjusted to 0, there are tens of MV, and the output voltage will jump around. And the TP terminal voltage will change from time to time 5.8-5.3v. When I add R9 to 4M, the output can be adjusted to 0, but it is also unstable and will change. But when using PHILIPSbc550c/560c transistors, the TP terminal voltage and output voltage are very stable and will not change, but R9 also needs to be added to 4M to adjust to 0v.
Old 3rd January 2020, 06:16 AM   #962
R1R2 = 56R, power supply 10vTP = 5V, working points are normal, play some high level CD, high frequency will break, how is it?
Old 16th January 2020, 10:56 PM   #963
Dave S is offline Dave S  United Kingdom
Now that On-Semi BC560C is obsolete are there any suggestions for alternative devices to the BC550/560C?
Which parameters are important when selecting parts for this circuit?
Old 17th January 2020, 04:33 AM   #964
keantoken is offline keantoken  United States
keantoken's Avatar
Mouser has OnSemi BC5x0C and they are actually the same Fairchild parts I original recommended, now that OnSemi has acquired Fairchild.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 17th January 2020, 04:40 AM   #965
keantoken's Avatar
It sounds like oscillation, or perhaps a bad connection somewhere. It could be you have an unusual layout that is causing a problem. You can use the Phillips transistors if they work better, but they have higher noise and I designed the Kuartlotron for the Fairchild (now OnSemi) parts.
Old 17th January 2020, 09:50 AM   #966
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
I don't see anything available
Old 17th January 2020, 10:11 AM   #967
silasmellor is offline silasmellor  Denmark
BC550CTA ON Semiconductor / Fairchild | Mouser Denmark
No more bc560 it seems, Mark Johnson bought them all )
Old 17th January 2020, 10:12 AM   #968
keantoken's Avatar
I was looking at the NPN, looks like the PNP is now obsolete. Hmm.
Old 17th January 2020, 06:51 PM   #969
Temp source
BC560C FAIRCHILD PNP LOW NOISE TRANSISTOR x10PCS | eBay
Old 20th January 2020, 05:59 AM   #970
I use the DIY dartZeel nhb108 Amplifiers, then your Superbuffer Amplifiers midpoint voltage will rise from tens of MV to 700-800mv, what is the reason for this? Do I add 4.7 UF capacitors to the input or output? Superbuffer output midpoint is already within 10mv
I have used the same Fairchild BC550CTABC560CTA (HFE/800) as you listed, when R9 = 2.7M, the lowest midpoint voltage is still tens of MV, when R9 = 4M, the midpoint voltage is still 10mv, TP = 5V, sometimes 4.8v and sometimes 5.2v. With PHILIPSbc550c/560c won't such, what reason is this?
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 4th January 2011 12:00 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 11:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 05:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
