The Kuartlotron - keantoken's simple error-correction superbuffer
Old 25th December 2018, 01:55 PM   #951
Zoran is online now Zoran  Serbia
Originally Posted by keantoken View Post
Try it with the AC187/188. The 2G339 is fast but the Vce limit is not quite where I would like it to be.
OK thanks.
But is there some resistor value to correct?
Should R1=R2 be lower values?
Old 26th December 2018, 12:44 AM   #952
keantoken is offline keantoken  United States
keantoken's Avatar
I think it will actually work fine with the circuit as it is. Try it and report the voltages at each transistor pin, then we can make some adjustments if necessary.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 27th December 2018, 03:38 PM   #953
OK
I will do it this way
thanks
Old 6th June 2019, 07:22 AM   #954
keantoken's Avatar
I am about to order a new batch of PCBs. The new PCBs will have curved traces but other than that will not be any different.
Old 7th June 2019, 07:10 PM   #955
Bigun is offline Bigun  Canada
Bigun's Avatar
I like that idea
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th June 2019, 06:57 PM   #956
keantoken's Avatar
The new PCBs are in.
Old 23rd August 2019, 10:56 PM   #957
JasonB299 is offline JasonB299
Default Push-Pull Kuartlotron
Hi Kean,
A young starting DIYer here. I am intrigued by your circuit. Have you ever tried a push-pull buffer like in the attachment? I guess referring to the enumeration from your site, the different Vce of Q1 and Q3 in this arrangement could be suboptimal for the error correction, because for transistors with limited VA the current through R1 and R2 and hence the Vbe of Q2 and Q4 would be different and signal dependant. But on the other hand the input capacitance of Q1 is now bootstrapped, which might help with high frequency linearity, when a high impedance source (read pot) is used. In any case, the buffer can now source and sink high currents by transitioning in class AB and - if I see it correctly - when Q2 and Q4 are thermally coupled as intentioned, the bias can be set by the current through the new input resistors and the ratio between input and output resistors plus, importantly, the bias is temperature stable. The only downside I can see in this regard, is that we will likely suffer from gm-doubling in the class A region due to the new output resistors, since the output impedance of each kuartlotron half is probably near zero from the error correction scheme.
What do you think about it?
Many greetings,
Jason
File Type: jpeg 100DFC26-8DE9-439A-AF64-BA3D4812D66C.jpeg (609.3 KB, 118 views)
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 4th January 2011 12:00 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 11:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 05:17 PM
Copyright ©1999-2019 diyAudio
