The Kuartlotron - keantoken's simple error-correction superbuffer
Old 22nd September 2018, 08:47 PM   #941
silasmellor is offline silasmellor  Denmark
Yeah I think it’s at min value, so essentially r9 is jumpered. Not sure what to make of it. On start up, tp slowly goes to 5v and offset to1-2mV.
Old 22nd September 2018, 08:48 PM   #942
Originally Posted by silasmellor View Post
Ok, using the 1M trimmer without the series 1.8M also works, so I suspect I’m just at the end of the travel for the pot, probably at low R. Would it make sense to try something even higher, like 2.2M for the Series resistor to R9? Is Avery low resistance for R9 a problem?
Sorry, that post should have said “without the 1.8M series resistor...”
Old 22nd September 2018, 10:22 PM   #943
Ok I think my benchtop psu might have been the issue. I switched over to the intended psu, 10v bipolar using Nisbeths standalone whammy psu boards. Added another 500k in series with the 1.8M one and offset is only a few mV without any trimming. I can play music through it so I guess it works, but I will try the fft to check distortion (though I doubt I can trim much as my interface won’t go below 0.006%.
Sorry for the confusion, not sure why the benchtop psu was giving odd results, it has +/- and gnd taps, but measuring gnd to either + or - showed 0V so something must have been off there...
Old 12th November 2018, 09:59 PM   #944
Zoran is offline Zoran  Serbia
Hi Ken. Could You transcribe superbuffer to Germanium transistor version?
(I have one full Ge amp and it need buffer to drive input transformer...)
I know that old Ge-s are maybe inferior against contemporary Si BJTs but I just dont like idea to mix...
thanks
Old 6th December 2018, 05:59 AM   #945
keantoken is offline keantoken  United States
keantoken's Avatar
Sorry, for some reason I tend to stop getting notifications from this thread.
I could take a stab at it, but I need to have datasheets for the parts you have available.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 6th December 2018, 06:48 AM   #946
keantoken's Avatar
I tried the Kuartlotron in the simulator with AC127/128 models, it does surprisingly well. Unfortunately not all Ge transistors are as useful as these.
The OC70 has a transition frequency of 15KHz. If I heard of a modern transistor with a Ft of 15KHz, I would assume it weighs about 100LB and is used only in special super high power applications.
Old 24th December 2018, 05:42 PM   #947
Thanks for answering Ken
(I need Ge buffer, t match with old restored Ge amp. Just to stay in a same "mood"...)
Westrex 2404-C Germanium Amp Restored
But I dont have experience how to transcribe to Ge. Biasing and other things. I am from vacuum tubes world mostly.
I will try to find some AC127/8
I have next Ge-s
Type Designator: 2G339
Normally replaceable-slightly different: AC127
Material of Transistor: Ge
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 0.15 W
Maximum Collector-Base Voltage |Vcb|: 15 V
Maximum Collector-Emitter Voltage |Vce|: 10 V
Maximum Emitter-Base Voltage |Veb|: 2 V
Maximum Collector Current |Ic max|: 0.3 A
Max. Operating Junction Temperature (Tj): 100 C
Transition Frequency (ft): 5 MHz
Forward Current Transfer Ratio (hFE), MIN: 150
Noise Figure, dB: -
Package: TO5
Type Designator: 2G381
Polarity: PNP
no datas
Type Designator: OC83
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 0.6 W
Maximum Collector-Base Voltage |Vcb|: 32 V
Maximum Collector-Emitter Voltage |Vce|: 20 V
Maximum Emitter-Base Voltage |Veb|: 3 V
Maximum Collector Current |Ic max|: 0.5 A
Max. Operating Junction Temperature (Tj): 80 C
Transition Frequency (ft): 0.4 MHz
Collector Capacitance (Cc): 100 pF
Forward Current Transfer Ratio (hFE), MIN: 40
Noise Figure, dB: -
Package: TO1
thanks again
cheers
Old 24th December 2018, 06:19 PM   #948
A have also
AC187-AC188
Old 24th December 2018, 06:24 PM   #949
I found some datas for small Ge already have
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 0.25 W
Maximum Collector-Base Voltage |Vcb|: 20 V
Max. Operating Junction Temperature (Tj): 85 C
Transition Frequency (ft): 1 MHz
Collector Capacitance (Cc): 50 pF
Forward Current Transfer Ratio (hFE), MIN: 75
Noise Figure, dB: -
Package: TO1
Old 25th December 2018, 12:45 PM   #950
keantoken's Avatar
Try it with the AC187/188. The 2G339 is fast but the Vce limit is not quite where I would like it to be.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 4th January 2011 12:00 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 11:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 05:17 PM
Copyright ©1999-2019 diyAudio
