The Kuartlotron - keantoken's simple error-correction superbuffer
Old 3rd September 2016, 07:37 AM   #671
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Destroyer OS. View Post
I hope this is your sense of humor; that or you're going to send me a $3k hot air bed station....
It is either that smaller layout or the added coil for the cost of a fast thing in an overlarge size. Seems like the needless coil is cheaper at the moment.
I did mine coin size with through-hole parts, just because that's what it looked it like it needed. Well, it was triple layer and not the prettiest thing; but, I've still got to say that when it is small enough, then the coil is not needed. I was told that it was supposed to be fast, so I built it for fast. Well, you wouldn't do otherwise. But, if you did, that's when you need the extra coil.
Sure, the new SMD things are awful, at least 1/3rd off the mark; however, they're a lot better than a foul layout. And, for a fast thing, a foul layout is one that is too big.
In this application, there is some leeway to consider using SMD parts.
Old 3rd September 2016, 09:13 AM   #672
jameshillj is offline jameshillj  Australia
What does a non-foul layout, fast thing, 1/3rd off the mark 'SMD things' (transistors?) sound like? Any better than a 'normal' slow thing with the 1/3rd 'on' devices? 100Meg Hz response?
Old 4th September 2016, 04:45 AM   #673
ammel68 is offline ammel68  United States
Banned
LOL...
Old 4th September 2016, 05:32 AM   #674
keantoken is offline keantoken  United States
keantoken's Avatar
If the transistors are slower, then that could adversely affect stability. The effect of the inductor can be simulated to work without parasitics added, because the inductors is compensating for the slowness of the transistors, not for layout.
The total trace length of the PCB inductor is 48cm. If it were adjusting for layout inductances, that would be too large (several times larger than the longest trace on the board), especially since the ground plane reduces trace inductance.
In terms of capacitive parasitics, the transistors themselves still have more capacitance than the traces that connect to them, so are the limiting factor. But the inductor isn't really compensating for the transistor capacitances. It's compensating for the junction transition time. The B-E junction behaves like an inductor at RF and this can cause too much phase shift even if Cbe is very small. This is why some circuits are near impossible to stabilize when you only think in terms of Cob or Cbe.
So again, even for inductances the transistors are probably slower than the layout.
I imagine the inductor plays little purpose except for edge cases, but having it there improves reliability in some cases and in simulation even improves distortion. If anything about layout worries me, it's pcb leakage. I forget what the general value is but I thought somewhere around 500Mohm+1pF or something like that. But that is swamped even by the 100k+15pF input impedance, and most DIYers don't seem to have had a problem with it.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 8th September 2016, 06:10 AM   #675
keantoken's Avatar
So, the new PCBs arrived. I'm looking for someone who can test a pair within a week or so, since I'm not sure when I'll get to it.
Old 8th September 2016, 05:22 PM   #676
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I would be glad to help please pm me.
RC
Old 9th September 2016, 10:28 AM   #677
Theodosis O. is online now Theodosis O.  Greece
Ηι,
How can we check that the BC550c/BC560c we have are from ON Semi ?
Is there a special code on them ?
Old 9th September 2016, 11:33 PM   #678
keantoken's Avatar
It's hard to describe since the current ones have very similar lettering. Mine have 3 lines:
BC560
C
[code]
The lettering has changed in the past. Some of my old ones have the FC lettering which is omitted on the new ones.
Old 10th September 2016, 06:54 AM   #679
Banned
Originally Posted by Theodosis O. View Post
Ηι,
Even though this listing has ended, look closely at the photo.
8 X Matched ON Semi BC550 BC550C BC560 BC560C LOW Noise Audio Transistor | eBay
Those are original ON Semi '550/'560s. I know since I have many of each.
If the markings aren't similar, they're probably made by some other manufacturer and/or fakes.
Old 10th September 2016, 06:56 AM   #680
keantoken's Avatar
For the Kuartlotron they should be from Fairchild, not OnSemi. The difference won't break it, but they are less suited for the current Kuartlotron.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 4th January 2011 12:00 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 11:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 05:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
