The Kuartlotron - keantoken's simple error-correction superbuffer
Old 11th August 2016, 12:46 PM   #651
gabanyayaya is offline gabanyayaya  Malaysia
Originally Posted by keantoken View Post
DIYaudio won't accept .xls files.
About 16-17mA, can be more or less.
does this means that using batteries is possible ?
Old 11th August 2016, 07:51 PM   #652
keantoken is offline keantoken  United States
keantoken's Avatar
Yes, but normal 9V batteries won't last very long.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 11th August 2016, 10:20 PM   #653
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
You could use some 1ah batteries setup so when you turn the buffer off it turns the charger on.
Old 13th August 2016, 12:42 AM   #654
keantoken's Avatar
Originally Posted by jameshillj View Post
Ah, I didn't now there was EMC problems with holes in a ground plane - doesn't apply to the component holes? Ideally, smd components only on the one layer?
Can bigger clearance holes, irregular shaped apertures, slotted/sectional planes (as per Tentlabs), etc reduce the EMC reasons or does any/all perforations create problems? [Is it a design protocol and how significant to sound quality would it be to ignore it?]
Circular holes are the most benign, so the pins aren't too bad. In most cases, perforations probably don't cause problems for audio unless there is a grounding mistake. But I figure, if it has a ground plane, why not go all the way? In any case, I was able to widen the solder rings.
I've also added some random solder pads for those that might want to add stuff, as well as a pad for one of the screws if you want to connect the board to chassis (sometimes there are reasons for doing so).
I'm close to getting this printed.
Old 13th August 2016, 02:44 AM   #655
Hearinspace is offline Hearinspace  Canada
If the 550 and 560 outline to pad position/size ratios are accurate reps of the real parts wouldn't it be good to move them closer together so there's no need to bend leads to have them touching?
Old 13th August 2016, 02:47 AM   #656
keantoken's Avatar
Same thoughts as I had, but then the text wouldn't fit or would be too small to read. Also there are traces running between them that need space. So I could move them closer but not by much.
Old 13th August 2016, 03:05 AM   #657
Are all pads NC? A pad for ground would be nice for 100nf caps to chassis. I run mine with a cap to chassis because my enclosure has too many small openings. The sound is much smoother with it.
Old 13th August 2016, 09:24 AM   #658
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
I'd like to see it at half the size.
Old 13th August 2016, 09:50 AM   #659
Theodosis O. is offline Theodosis O.  Greece
and with SMD components.
Old 13th August 2016, 07:18 PM   #660
Oh well, it's easy to back seat drive, I'll shut up and leave you to it. I think I can manage shaping a lead or two
Going through the thread in spurts, I haven't seen a drawing with the 431's in. Do you have one to post or is that part of the circuit still evolving? Just curious.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
