The Kuartlotron - keantoken's simple error-correction superbuffer
Old 18th February 2014, 07:34 PM   #51
keantoken is offline keantoken  United States
keantoken's Avatar
Originally Posted by Zero D View Post
I tried various Caps in the following position, & the 1nf boosted the HF -3dB up to over 1GHz ! THD was still below 0.001% @ 20kHz with 1V RMS
Whether this would be stable etc in Reality ? Even if it's OTT for audio, it "might" be a useful technique for video ?
That works great with low source impedance, and a source that's willing to drive the entire buffer at 1GHz. But it causes negative input resistance which turns your input cable into an RF transmitter, or at the least cancels the loss of the preceeding wiring and boosts RFI reception.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th February 2014, 07:34 PM   #52
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
philosophical ?
Yes, in my view, bcs it exploits philosophy on intrinsic semiconductor characteristics than brute force to attend its goals.
Old 18th February 2014, 07:50 PM   #53
keantoken's Avatar
I am planning to use the Kuartlotron just after a jfet common source high gain amp stage.
It outputs 10v DC offset modulated by signal.
Maybe I can build the stock buffer with simetrical psu (so I will loose output cap) but would like to increase it's input impedance to 1mega so I can use a small cap in the input.
What is signal ground referenced to? If it's on the same supply, I need to know where the reference is. If isolated supply, then I can make a single-rail version without coupling caps. It may be that you will end up needing caps in the signal path if you want to power it from the same supply as your Jfet circuit.
Old 18th February 2014, 07:53 PM   #54
keantoken's Avatar
Yep, I think the Kuartlotron is very philosophical in that sense.
Old 18th February 2014, 08:30 PM   #55
forr is offline forr  France
forr's Avatar
The princinple of the circuit is similar to the one shown by figure #12 :
( source : entree )
Old 18th February 2014, 09:02 PM   #56
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
" There is nothing new under the sun "
Salomon
Old 18th February 2014, 09:15 PM   #57
keantoken's Avatar
Nice! The lowest-distortion output point for this circuit is the emitter though, not the collector. Still, it behaves like an ideal transistor and could go in virtually any place you'd use a transistor, for instance LTP, drivers, buffers, and so on.
Old 18th February 2014, 09:56 PM   #58
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
So is this the answer to the question of what to put in front of the OP section Ostripper has designed, or H/k if we want to give them the credit? Would this complete the CFA amplifier design?
Old 18th February 2014, 10:13 PM   #59
keantoken's Avatar
Kindhornman, I'm not sure.
I notice many people slap on different topologies of input, VAS, etc onto an amp without actually checking if that stage is even a significant source of distortion in the design.
I would say the Kuartlotron as a CFA frontend would be great IF it were shown that the input stage was a source of distortion in the first place and that the Kuartlotron would not cause the same distortions. I'm inclined to believe that the input stage of a CFA amplifier is not a significant source of distortion unless it is a very low-gain input stage - in which case, any high-gain input stage will work well, not just the Kuartlotron.
All these things depend to an extent on the specific amplifier. Some CFB amps may be improved, others may not.
Old 18th February 2014, 10:23 PM   #60
Thanks Keantoken,
It seems like we have come down to perhaps this type of input section or the diamond for the front end of the CFA. I haven't seen to many proposing the LTP type of input for the CFA but perhaps I have been misinterpreting that? I am just an observer here so I am trying to learn and see what a few of you gurus seem to being directing this end towards. The triple output section seems to be the most relevant but I understand that the double EF can also be made to work.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Copyright ©1999-2019 diyAudio
