Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#521 | |
#522 |
#523 |
@Keantoken: I have a doubt about Vbe(Q4) and Veb(Q3). One left channel I measured Veb(Q4) = 0.6649, Veb(Q3) = 0.6017. So after calculating it becomes 60.0632. Similarly right channel is 60.0673. Is this the calculated value for R1 (=R2)?
#524 |
Yes, that is correct. Notice that is just a 7% difference from the original value of 56.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer! Need something built, repaired or modded? PM me and ask what I can do! |
#525 |
Thanks!
I did the usual checks and adjustments (0.012 - 0.014 mV DC offset). This time there is absolutely no hum or hiss. I'll need some burn in as I'm experimenting with a thicker solid core internal wiring (20 gauge, Teflon insulation). |
#526 |
Banned
#527 |
Hello ammel68!
I used this transformer. https://www.reichelt.de/Transformers...tnr&OFFSET=500 For the sprint layout file is importing gerber because originally the layout has been designed with DesignSpark. |
#528 |
Banned
Hello Project16,
Thank you for the zip file! I'll have to search around and see if I can find a suitable transformer from Mouser or some other seller over here. |
#529 |
Another software based test.
#530 |
Can you list the exact parts you used? Is this before trimming?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New error correction amp | PMA | Solid State | 101 | 3rd January 2011 11:00 PM |
error correction et al' | sq225917 | Digital Source | 4 | 7th August 2007 10:16 AM |
Visual error correction? | Circlotron | Everything Else | 4 | 15th September 2003 04:17 PM |
New To Site? | Need Help? |
