The Kuartlotron - keantoken's simple error-correction superbuffer
Old 18th February 2014, 12:24 AM   #31
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Well, not cut but just take the krocodile clips away.
Old 18th February 2014, 12:33 AM   #32
Take away the green and yellow clips from the ground plane on the buffer.
Old 18th February 2014, 12:33 AM   #33
Martina Schoener is offline Martina Schoener  Germany
Martina Schoener's Avatar
Hi Joachim
... I am off driving to Vienna now, but will take the Kiso and Amp with me
so either there or when I am back I will try that
- signal source then in Vienna might be the Immedia from Michi , his CD Digital pre
or my blutooth Iphone files ;-)
Looooooong drive now!
Good Night!
Martina
Old 18th February 2014, 12:39 AM   #34
OK.
The other could try in simulation if a floating supply works.
I found it works most of the time also with other circuits.
There is much more to say about this but that has to wait for later.
Old 18th February 2014, 12:41 AM   #35
PS
.... I would never "cut" crokodiles nor their clamps...
even though removing crokodiles from ones buffer might need "expertise'
.... Crokodile dundees everywhere
Old 18th February 2014, 12:46 AM   #36
Hopefully better image now
Old 18th February 2014, 12:50 AM   #37
Yes, that is better.
Old 18th February 2014, 12:53 AM   #38
This is the Keantoken buffer.
Old 18th February 2014, 01:57 AM   #39
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Joachim Gerhard View Post
It could work on a floating suppy. So 20V with no ground connection.
OK.
A small bit of data:
Yes, that works.
The 50/50 resistor divider used on mine is 400 ohms and 400 ohms (with 0v at centerpoint), and the power is 20v with LM317. Generally, a chip buffer will perform horribly with that setup; however, it didn't bother Kuartlotron at all. It didn't go dull! I could have assembled a chip based solution faster, but it would not have completed quickly due to performance. However, the Kuartlotron assembled reasonably quick, and "scored a home run" with its good performance meaning it was completed. SO, despite messing with transistors and layout, the Kuartlotron, being a plug and play performer, is actually the easiest buffer solution that I know of.
You won't get stuck with resolution and tone issues--those are problems it does Not have.
Old 18th February 2014, 04:21 AM   #40
Originally Posted by RCruz View Post
Any recommendations on what to use for the coils L1 2uH ?
For historical references only, here is the older version of Kuartlotron that doesn't use the inductor. http://www.diyaudio.com/forums/attac...stabilized.png
P.S.
I have a model that is older than that and it still outperforms a chip.
P.P.S.
Post #26 has an easy way to build the inductor for the new model.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Copyright ©1999-2019 diyAudio
