The Kuartlotron - keantoken's simple error-correction superbuffer
Old 6th May 2015, 02:05 AM   #241
jameshillj is offline jameshillj  Australia
Ah, right - simple.
I had another question about your webpage that I can't figure out and wondered if it's a misprint - this is just below the diagram of the 'ideal transistor' - the underlined bit
The mechanism that causes this result is surprisingly simple - Since Ic(Q2) = Ic(Q4), Vbe(Q2) = Vbe(Q4). Similarly, Ic(Q1) = Ic(Q2), so Vbe(Q1) = Vbe(Q3). Since Vbe(Q3) = Vbe(Q4), this means Vbe(Q1) = Vbe(Q2), which is to say, the Vbe of Q1 is directly cancelled by the correction signal across Vbe(Q1).
Thanks ... James
Old 6th May 2015, 02:53 AM   #242
keantoken is offline keantoken  United States
keantoken's Avatar
Oops, that needs to be corrected. It should be
... the Vbe of Q2 is directly cancelled by the correction signal across Vbe(Q1)
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 6th May 2015, 03:50 AM   #243
arthur is offline arthur
Apart from Vbe, do we need Hfe matching and N P matching ?
Old 6th May 2015, 03:53 AM   #244
keantoken's Avatar
No. N/P matching may actually worsen performance.
Old 6th May 2015, 01:21 PM   #245
Project16 is offline Project16  France
Project16's Avatar
I hope not bother you too!
I have made some arrangement and I have two suggestions for the layout of the ground track.
Thank you for your answers!
Old 6th May 2015, 03:54 PM   #246
I like the first one best (left hand design) with the more symmetrical arms to the power caps and the way you've separated the IN & OUT ground pins - R7 & R8 belong to this current path, not the power supply tracks, and moving R2 upwards fixes R7, but R8 not so easy - another way would be to exchange R7 and C3 positions, and also exchange R8 and IN terminal and push up that R8 into a new gap created between R9 & R5 .... interesting, eh!
You could perhaps squeeze the R11 vertical instead of the link - might need to alter tracks around R9 but quite 'do-able' - you might add a bit more clearance on the C4 & C5 caps.
I wonder if the IN & OUT terminals could be brought a bit closer to the board's edge - the track R6 to R4 is the problem - the only way I see around it is to put the R4 underneath and use it 'stretched out' as a link to a donut next to R6, but not very pretty and subject to mistakes - hmm!
As this is just the single channel, I wonder if it's worth looking at adding another mirror image buffer (with appropriate transistor adjustments) on the left hand side of the power input terminal for a stereo buffer and you wouldn't need to duplicate the caps C4 & C5 - just an idea (the pots R1, R5 & R9 make it impractical to stack them on top)
As 'kt' mentioned above, you could add a 2nd layer that would replace the capacitor return tracks and provide ground plane merits, but with this simple design, we could make these boards at home
I have a habit of squeezing components a bit closer together - you could perhaps do the same here - it looks to be about 60 x 50 mm at present?
Looking good, IMO
Old 6th May 2015, 06:00 PM   #247
Project16's Avatar
Jameshillj thank you for the advice.
It's better like that?
The dimensions of the circuit are 5.0 cm x 4.5 cm
Regard's!
Old 6th May 2015, 06:55 PM   #248
MisterRogers is offline MisterRogers  United States
I second the request to have two channels on a single board. Not a big deal, but I imagine the majority of time these will be built in stereo pairs.
Old 6th May 2015, 07:40 PM   #249
Project16's Avatar
To shorten a little some tracks I have changed the connections to the pads trimmers, the rotation does not matter I think. I also made a small change on the ground track of R7 and R8.
Old 6th May 2015, 11:41 PM   #250
Looking rather neat now - like that track for the R7 & R8
Maybe have another look at the trimmer pots, at least R1 & R7 anyway - turning the adjust knob clockwise will increase 1 trimmer but decrease the other - perhaps it might be worth making them consistent
Apart from that it seems to be pretty complete - any thoughts about maybe a stereo version - if you were to add this to the 'DirtyPCB' list, a double sized board would cost maybe U$25, instead of the basic U$14, and complement 'sikahr's' boards well.
... later
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Copyright ©1999-2019 diyAudio
