The Kuartlotron - keantoken's simple error-correction superbuffer
Thread Tools
Old 20th April 2021, 08:26 AM   #1011
Cney is offline Cney
How does one order these? The post that I got sent to doesn't say.
Old 20th April 2021, 08:54 AM   #1012
keantoken is offline keantoken  United States
keantoken's Avatar
You can PM me.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 29th April 2021, 02:37 AM   #1013
sonidos is online now sonidos  United States
Libertador de la Música
sonidos's Avatar
I finally started building my boards but have a question. In this latest iteration, I have several Fairchild transistors on tape. Is it recommended to match Vbe for the buffer? I ran through the posts and wasn't quite sure if skipping matching would invite this to be unstable.
Old 29th April 2021, 06:46 AM   #1014
Zoran is offline Zoran  Serbia
Originally Posted by TNT View Post
1941 has no offset on output. Output impedance is 560 ohm per half.
IF You cut out all other nets from the output of R2R ladder network. Just FPGA and R2R net - it should have offset of 1/2 power supply at ladder net.
The output impedance for R2R based topology should be R value...
That is for DAC device only without any following analog stage, buffer or amplification stage
Old 29th April 2021, 07:01 AM   #1015
I tested one more version with JFET "input" and Ge "output" devices. Working very good. Same like full Ge, but with higher input R. For Ge-s I tried 2 types AC187 with lower Io, and AD161 with higher Io, but without owerhating without heatsink.
I tested this because I have almost all elements on board. just exchanged 3 elements.
More common types for Ges anf JFET version is bellow.
Old Today, 03:05 PM   #1016
3SSS is offline 3SSS  Russian Federation
I liked the transistor assembly that340 which consists of 2 pnp transistors and two npn. The transistors are located on a single die and have a very low noise level. I would like to apply it in this scheme. But she has a small hfe of only 180-220 ... Question to the author, is it possible to use it?
http://www.thatcorp.com/datashts/300data.pdf
  Reply to this post
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
Thread Tools
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
