MUSES 72320 electronic volume
Thread Tools
Old 26th January 2021, 11:42 PM   #581
amandarae is offline amandarae  Philippines
amandarae's Avatar
I built two of this and both are working fine with or without the display (Adafruit) and with or without using the LDO. After I solved my noise problem and doing some experimenting, I observed that it work if the supply is less than +-15 but with the +5V external (from a different supply). I was unable to "fire" it up if I use less than +-15 and internal +5V.
The specs says +-8.5V to +-18V. But I am not sure why on my two units, I have to use external 5V if my supply is less than 15. Hope you find the problem!
The power supply of my power supply is my FRIEND!
Old 27th January 2021, 07:47 AM   #582
bambadoo is offline bambadoo  Norway
Thats interesting but I dont think it explains this?
Only running the controller board now and the LDO circuit is fed with +14v (also tried +10v). Ideally I assume approx 6-7Vdc would be perfect for that purpose.
No display connected
Of course I can crank it up some but I cannot understand how that would improve things?
Only thing I can come up with is that Mouser sent me LDO with different pinout? (D-config)
This was what I ordered
https://no.mouser.com/ProductDetail/...rrencycode=NOK
https://no.mouser.com/datasheet/2/38...20-1374943.pdf
Not sure how I can check that yet, and could that cause this problem?
File Type: png Skjermbilde 2021-01-27 kl. 08.41.58.png (73.8 KB, 187 views)
Old 27th January 2021, 07:50 AM   #583
meldano is offline meldano  Germany
Yes!
Muses v2 Volume Kits available
https://www.diyaudio.com/forums/swap...es-volume.html
Old 27th January 2021, 09:21 AM   #584
Ok, use what I have and it works. 5v out of pin3.
Guess I got the wrong pinout. Vin then got shorted to gnd.
Old 27th January 2021, 01:51 PM   #585
Ok it works fine.
Behold of the beautiful test setup here
Will have to buy a new LDO thats fit to the board...
Old 27th January 2021, 01:53 PM   #586
Perfect
Old 27th January 2021, 02:36 PM   #587
Not to self. Read datasheets before ordering components.
Old 27th January 2021, 04:11 PM   #588
amandarae's Avatar
Originally Posted by bambadoo View Post
Ok it works fine.
Behold of the beautiful test setup here .
Great!! Nice to know you have sorted it out.
  Reply to this post
MUSES 72320 electronic volumeHide this!Advertise here!
Thread Tools
KIC9482F electronic volume control madanthonie Parts 1 10th January 2014 07:07 PM
Electronic volume control idea Elvee Analog Line Level 3 9th August 2011 09:24 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Noisy electronic volume control SU-G95 Mailliw Solid State 0 23rd April 2007 08:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
